Removing sharp perforation edges on stators with ferric chloride - Page 4 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 9th July 2007, 11:59 PM   #31
Those of you brave enough to try the lye method should heed bear's warnings about safety religiously. His suggestion of having a mild acid such as vinegar on hand to neutralize the lye is sound advice indeed. Add the acid slowly, however, as the solution will froth up violently if you add the vinegar too quickly. Keep adding the vinegar a little at a time, until the solution stops bubbling, then add a bit more. The result will be a slightly acidic (but safe) solution of Sodiun Acetate.
You can obtain lye (sodium hydroxide) in most home improvement centers as drain cleaner. Red Devil brand is the purest. READ THE LABEL before you buy it! If there is anything in there besides Sodium Hydroxide, keep looking. Newer drain cleaning products such as Drano often incorporate additives (even aluminum shavings) to make them evolve gas to "blow" the obstruction down the pipe.
Those of you considering HCl or pool acid for etching should immediately lose that thought. When aluminum is dissolved in HCl, the gas evolved is hydrogen, which is explosive. The fumes from HCl will rust every tool in your shop, not to mention tearing your lungs out.
Most importantly, if you choose chemical etching, work in an open, well ventilated area. Preferably outside. I for one am sticking with wet sanding, and orienting the sharp side away from the membrane.
Old 10th July 2007, 09:50 AM   #32
Hi Folks,
anything you do without the assistance of current is etching, which won't round sharp edges as required.
Only electropolishing will do, since it will remove material especially at sections of highest field densitiy and those sections are edges and burrs.
If you cant electropolish the better compromise is sand blasting with fine grid.
Capaciti
Old 14th July 2007, 08:19 PM   #33
expert in tautology
bear's Avatar
Probably a very fine grit glass bead is best...
as far as etching for this process.
seems to me etching will work equally on all surfaces, so areas with greater surface area, and that are thinner will be removed by etching before a significant reduction of overall thickness occurs. that would be the burr... thin, and with higher surface area than the flat?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 15th July 2007, 02:56 AM   #34
auplater's Avatar
_-_-bear
Not exactly... etching is purely geometrically driven... so to a linmited extent, what you say CAN happen. BUT, as the higher relative etching rate (due to surface area) occurs, you also deplete the etchant more rapidly, and it slows back down to the diffusion limited rate of fresh etchant to the surface.
Electropolishing, OTOH, drives the reaction with a differential between the etching process (dissolution) and the diffusion of the active material being etched away from the surface.... the boundary layer of reactants is thinner over projections than it is over depressions in the surface, thereby creating a higher current density on the projections and thus resulting in a differntial etch rate in favor of removing burrs and projections faster than smooth continuous regions....
in case anyone wants to know...
John L.
"I've forgotten more than I care to remember" The Last Conspirators
Alu stators, holes/perforation aligned? bentl Planars & Exotics 2 22nd April 2009 08:00 PM
MDF edges and screws rinx Multi-Way 32 16th August 2008 03:36 PM
Help: ferrous chloride/water ratio theAnonymous1 Everything Else 41 30th March 2007 08:50 AM
ferric chloride hacknet Parts 27 19th December 2002 07:41 PM
Copyright 1999-2017 diyAudio
