| Planars & Exotics ESL's, planars, and alternative technologies |
We all know the water bending experiment with a charged comb. Does steam behave this way? How about charging some steam and passing it over some kind of conductor with the opposite charge modulated with a signal?
I could write more but I think the mechanics of such a thing are fairly obvious Anyone ever tried this? |
#2 |
The mass of such a diaphram would be quite substantial, no ?
I recall reading more than a decade ago ... a speaker that used ionised Ozone, as a diphram responding to an electric field.... |
#3 |
Bigwill,
What sort of steam did you have in mind Dry or Wet ? Wouldn't wet steam be rather a problem especially in a humid climate ? And dry steam is just downright lethal, we use 350 deg dry steam @ 700psi. Perhaps modulating a high pressure feed would be the answer, we could use the steam to move a small piston connected to a loudspeaker diaphragm
#4 |
What I had in mind was small jets of steam fired at some kind of mesh with a high voltage signal applied to it (as well as a high voltage bias)
The steam would be attracted (or repelled depending how you charged the water) in sympathy with the audio signal, hopefully creating pressure waves |
#5 |
An ionic breeze converted into a speaker using water vapor (ultra sonic mister or something) sounds like my idea of fun
| resonant frequency of water (distilled) and how to make speaker play underwater | Audiophilenoob | Multi-Way | 100 | 20th July 2011 10:15 PM |
| Mercury Vapour rectifiers | Craig405 | Tubes / Valves | 16 | 14th February 2006 03:34 AM |
| Using 866A Mercury Vapour Rectifiers? | SHiFTY | Tubes / Valves | 18 | 28th January 2005 03:29 AM |
| Water cooled plate on ebay (possible water cooled amp application) | BrianGT | Parts | 1 | 27th May 2002 04:19 PM |
| Page generated in 0.07463 seconds (73.31% PHP - 26.69% MySQL) with 10 queries |
