Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 24th May 2007, 06:53 PM   #1
wrl is offline wrl  United States
Default Leave ESLs Charged or Switch ON/OFF?
Hi all,
I was wondering how many of you leave the ESL diaphram constantly charged and how many power it up every time you listen. In the past I have left mine charged, but I'm more concerned once I rebuild that my cat may decide to use the panels as scratching posts while I'm gone. Also a healthy dose of paranoia that I shouldn't leave diy stuff plugged in when I'm not around.
My problem is that I have 100 Mohm resistors in line with the diaphram so it takes quite awhile to fully charge (I'm guessing ~1hr). Can I safely decrease this value and cut down charging time? Also, is there any inherent advantage to leaving the panels charged (i.e. is repeatedly charging/discharging bad for the diaphrams?). I'm using perforated metal stators with mylar and coating from ER audio. I forget the exact description.
Thanks for your input,
WRL
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was.
Old 24th May 2007, 07:32 PM   #2
oshifis is offline oshifis  Hungary
I leave mine permanently on (Quad ESL 57). It takes several hours to charge, they reach full performance after one day.
A hint: try a miniature neon lamp instead of the resistor. It has low resistance when the voltage difference between the diaphragm and the voltage source is higher than about 80V, but it has infinite resistance at low voltage difference, when the diaphragm is nearly fully charged. It does drop charging while maintaining infinite load resistance. It charges more quickly, and an added bonus: you can visually detect any leakege (then it charges permanently, and the neon is glowing or blinking).
Old 24th May 2007, 10:25 PM   #3
maudio is offline maudio  Netherlands
Default Re: Leave ESLs Charged or Switch ON/OFF?
Even a very large panel (say 2nF capacitance) will charge in < 1 second through 100 Mohm. So decreasing that resistor will not make any difference, when they take an hour the problem is in your membrame coating or in the connecting between membrame and HV-unit.
My ESL's reach full charge in a matter of seconds through 66 Mohm (using the EC coating from MJ Dijkstra). I always switch them off when not in use, to extent life span and it makes me sleep better
Old 24th May 2007, 11:17 PM   #4
bear's Avatar
On.
Definitely on.
No good reason why that should be.
As the previous poster said, they would seem to be fully charged and functional reasonably quickly.
However they do not seem to work quite like that to the ears.
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
Old 26th May 2007, 06:51 AM   #5
Calvin is offline Calvin  Germany
Calvin's Avatar
usually the charging time is much lower than 1 minute, which would mean that You´d better switch off the ESL for energy, ageing, dust and dirt attraction and safety reasons.
On the other hand I feel that sounds improve with my panels over a period of ~2-3 hours. The effect isn´t dramatic and it might be illusionary or a matter of ´learning´, but since others report on the same effect, there might be something to it. This would imply to leave the speaker always on.
I switch it off, because the above named effect is really small and I don´t like to have many devices idling in a standby mode for basically no good reason.
jauu
Calvin
Old 27th May 2007, 05:38 AM   #6
Leaving the mylar charged is slowly eroding it. After a few years of being left on the mylar will get holes, etc. in it.
How is Quad 57 Treble Diaphragm Charged? markzb Planars & Exotics 8 16th May 2009 07:02 PM
Dose a Capacitor have to be pre charged every time? boogeronmyfinge Power Supplies 7 24th December 2008 09:52 AM
Guitar Amps, Overdrive Pedals, and Space Charged Tubes Turbo7MN Tubes / Valves 14 14th November 2006 12:38 AM
Being charged for chip samples kiwi_abroad Parts 9 19th September 2002 03:55 PM
Page generated in 0.10012 seconds (77.19% PHP - 22.81% MySQL) with 10 queries
