| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
Thanks.
I have ideas to build a tweeter out of two 0.8 mm thick PCB's and glue the diaphragm on it with double sided tape used to stick ornament and such on the wall/ceiling. This stuff is also 0.8 mm thick and can hold 50kg per xx cm. (dont know exactly) The PCB's are 160 x 100 mm and have single sided copper. I think i will cut out 1 area of 130 x 70 mm and solder 0.8 mm diameter wire on it, spaced 0.8 mm apart. Does it make any difference for the electrostatic field to place them on the long or short side ? grtz ST |
| High efficiency tweeter | JC951t | Full Range | 18 | 15th July 2009 04:56 PM |
| tweeter - How to attenuate or reduce efficiency? | Nordic | Multi-Way | 3 | 29th November 2006 11:51 PM |
| Looking for a high efficiency tweeter ... recommendations | paulspencer | Multi-Way | 0 | 13th May 2004 11:04 AM |
| High efficiency 2 way using Eminence Alpha6 + Horn tweeter | BlackUnikorn | Multi-Way | 9 | 16th April 2004 10:19 PM |
| Page generated in 0.05563 seconds (66.90% PHP - 33.10% MySQL) with 10 queries |
