| Planars & Exotics ESL's, planars, and alternative technologies |
I found this ion generator kit on eBay
http://cgi.ebay.co.uk/ELECTRONICS-KI...QQcmdZViewItem The output looks adjustable. Any reason why this wouldn't work? Buying this as a kit would be very convenient for me.. |
#2 |
It looks like it would provide adequate voltage at a safe current level. I'd say it's worth a try.
I_F |
#3 |
for the most part (most of the time) the air in your home is positively charged. This means that a positive supply to your diaphragms will help repel your rooms air and any contaminants in it. This will help to keep your diaphragms cleaner and minimise the amount of potentially conductive build up on your skins that will eventually lead to some bleed from the conductive section of the diaphragm to the frame. As a note all of Jim Strickland's (Acoustat) high voltage supplies were positive. Charge potential has no impact on the panels performance as far as I know. But if you can run positive it is probably woth your while. Regards.
moray james |
#4 | |
#5 |
looks like a very nice supply. Remember too if your budget is tight that you only need one supply to charge both panels. This does mean that you would have to run a supply wire to each speaker but makes for a 50% cost saving. Let us know how it works out for you and what kind of voltages you can get off of this supply. Regards.
moray james |
#6 |
Well I have ordered one so we shall see what happens!
#7 | |
You have to like the side benefits of owning ESLs:
Brian |
#8 |
Alright, it arrived today. It took about 20 mins to build and it worked on the first try
Here are some pics: http://www.bluebeard.plus.com/hv1.jpg http://www.bluebeard.plus.com/hv2.jpg It seems to work nicely! It certainly hurt when I accidently put my finger across one of the multiplier caps too! |
#9 |
Is that a small blue spark in the second photo?
BTW. When you turn the power source off does it still hold a HV charge? Looks very neat. |
#10 | |
Yes that is indeed a small spark! As for it retaining HV, it seems to. If I put a screwdriver onto the output after turning it off I get a small click. The capacitors certainly retain a charge as my poor finger found out! |
| What BIAS current is suitable for me? | lscangus | Pass Labs | 29 | 2nd February 2006 11:04 AM |
| Suitable bias for 4 ohm subwoofer over 200W? | EWorkshop1708 | Solid State | 12 | 21st January 2006 06:09 PM |
| Suitable chip for 12 volt indoor supply | Winnie | Chip Amps | 28 | 16th September 2004 10:44 AM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 09:49 PM |
| suitable inductors for alephX supply | nobody special | Pass Labs | 15 | 31st January 2003 01:54 AM |
| Page generated in 0.12466 seconds (77.99% PHP - 22.01% MySQL) with 10 queries |
