Planars & Exotics ESL's, planars, and alternative technologies
So I got some 6um mylar
Old 13th April 2007, 08:40 AM   #1
bigwill is offline bigwill  United Kingdom
Default So I got some 6um mylar
And it doesn't feel much thinner or lighter than clingfilm? Are they both so light that it's difficult to compare them or have I been sold rubbish?
Old 13th April 2007, 09:10 AM   #2
maudio is offline maudio  Netherlands
Folding it 6 or 7 times makes it thick enough to measure with reasonable accuracy using a caliper (slide rule). Should give you a good estimate.
Old 13th April 2007, 10:09 AM   #3
MJ Dijkstra is offline MJ Dijkstra  Netherlands
Assuming that you have bought 6 micron thick membrane indeed, you could be right that it is not thinner than clingfilm because clingfilm is really thin (but not as strong and durable as Mylar).
You may try some 4 micron. You can feel the difference between 4 and 6 micron and according to several builders hear the difference too.
drs M.J. Dijkstra
Old 13th April 2007, 11:28 PM   #4
Oops, of course, I meant micron in the title of this thread, not micrometers
Old 14th April 2007, 07:53 AM   #5
Doesn''t matter, micron and micrometer is the same.
drs M.J. Dijkstra
Old 15th April 2007, 08:59 PM   #6
ak_47_boy is offline ak_47_boy  Canada
My mylar is very crinkly compared to cling wrap. Its unbelievably strong, a 1" strip is hard to break. I measure mine at exactly 6uM.
Old 15th April 2007, 09:12 PM   #7
Mine seems very much the same
I'm pretty sure my mylar is ok after further inspection
Old 15th April 2007, 11:34 PM   #8
LineSource is offline LineSource  United States
LineSource's Avatar
If it's Dupont Mylar it is probably 6.3u thick = 25 gauge
Mylar is the Dupont trade name for polyester film. The Dupont Mylar catalog shows:
special order: 2.5u (10 gauge), 3.8u (15 gauge)
standard thickness: 5u (20), 6.3u (25), 8.8 (35), 12u (48) and up
Sound Lab ESL are spec'ed at 2-2.5u Mylar. Mylar supports 4000 volts per mil(0.001")
So I got some 6um mylarHide this!Advertise here!
Use of pre-metalized mylar willyCJ Planars & Exotics 4 19th June 2007 08:11 AM
How thick for MYLAR??? Dominick22 Planars & Exotics 46 14th December 2005 03:06 PM
Mylar Thickness ?? ERICSPEEd Planars & Exotics 25 27th May 2005 03:40 PM
From glass to mylar peterr Tubes / Valves 11 11th November 2003 01:19 PM
1/2 mil Mylar for ESLs phishead8 Planars & Exotics 12 17th December 2001 03:05 AM
Copyright ©1999-2017 diyAudio
