Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 30th December 2008, 12:45 AM   #31
a.wayne is offline a.wayne  United States
Sin Bin
could you guys post some pics ?
Old 30th December 2008, 10:35 AM   #32
JAMESBOS is offline JAMESBOS  England
Hi Wayne
If you go to post 25 on the previous page then look at post 1458,1460,1461 this will give you the general idea to build a full range planar, using ferrites or neos. Regards Anthony.
HENRY
Old 31st December 2008, 01:08 PM   #33
WrineX is offline WrineX  Netherlands
WrineX's Avatar
anybody has tried a small planar ? for only the mids and high from 1k and up ?
everybody is making fullrange but i like to keep the whole systemm small, also the panel cant be verry width because of beaming the high frequency. cant fin it anywhere on the site and i would really like to start with this kind of small project, before buying 200 neo's
Old 1st January 2009, 07:21 PM   #34
Corvus corax is offline Corvus corax  United States
Are all the poles facing the same direction on these magnets or are they flipped in rows? Also, what kind of adhesive are you using to glue those fellas down? I sure would hate to get my fingers pinched by 250 large grade 45 NDs!
Old 1st January 2009, 11:17 PM   #35
Hi Corvus,
The magnets are in alternate rows N S N S etc, and you don't have to glue them down as the perforated steel sheet holds the magnets down as they are quite powerful. The magnets I use are 50mm x 12.7mm x 3mm. These are easier to control. Bigger magnets would be more dangerous. I have trapped my fingers a few times! Nasty blood blisters! These neos are very powerful and can only be separated by sliding. So care and patience is the order of the day.
Regards Anthony.
HENRY
Old 17th July 2010, 05:30 PM   #36
Have just built my first push pull full range planar size 40 x 60mm, am very happy with it it is as loud as my 4' x 2' full range planar. I am going to build one using neos same size. The ferrite one weighs in at 14 kilos. The neo one will be a lot lighter and more sensitive. I shall concentrate on the push pull design for all my future constructions. This is the way to go.
HENRY
Old 18th July 2010, 12:18 AM   #37
The size should read 60 x 40cms silly me.
HENRY
Old 18th July 2010, 03:37 AM   #38
Sin Bin
James ,
I'm getting ready to do a push pull bass unit and I do plan on using Bars as opposed to perf sheets as you did. Still curious to see what you have come up with on yours, I cannot tell from the previous pics posted .
Could you post some pics on the finished unit ...
regards,
Old 18th July 2010, 04:06 AM   #39
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by a.wayne View Post
James ,
regards,
hey wayne
just a small note
remember to have front and back magnet with N to N towards each other, and S to S
if you choose front/back N to S, then you will get sidewards movement instead
one advantage is that front and back magnets wont attrackt each other, thus wont clash together
though I doubt its simple
magnets do strange things
and the field may not behave as intended
before buying all those expencive magnets, I suggest to build a small model, to see how it behaves
and its very tricky to assemble
you can only handle one magnet at a time
do not try to make larger sections
those magnets are impossible to control in multiples
sometimes we know very little, and sometimes we know too much
Old 18th July 2010, 09:28 AM   #40
I use 2 diaphragms so you can put the magnets on either side of the perforated sheet N to S so there is no clashing of magnets or any danger of the magnets jumping about. This works fine as I said before the 600 x 400 mm push pull full range planar is as loud as my 4' x 2' creation in red. I'm having difficulty loading my pictures on this site. I will put the picture of my new p/p frp on another site well my Grandson will as he is the computer expert.
HENRY
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 02:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 11:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 08:38 PM
Copyright ©1999-2017 diyAudio
