Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 19th August 2013, 05:39 PM   #301
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
have you considered smaller modules for line array ?
Old 19th August 2013, 11:34 PM   #302
JAMESBOS is offline JAMESBOS  England
Makes no difference really.
HENRY
Old 20th August 2013, 11:46 PM   #303
HENRY
Old 21st August 2013, 06:28 AM   #304
Originally Posted by JAMESBOS View Post
a line source is like a 5 feet tweeter
a line array is attempting the same by stacking multiple drivers
Old 21st August 2013, 07:20 AM   #305
Too busy at the moment trying to make my final designs final and the best I can manage.Have several ideas floating around inside my head, will have to see how things go. I have a re-build using magnetic tape to do. I got some more MDF from my grandsons old bed. So will have to think about various designs, although I have several more re-builds to do with my 60 x 40 mm designs.The magnetic tape designs have worked out quite well and cheaper magnet wise. Still life and ideas in the old dog yet! The only problem is lack of space, rapidly running out. Plus the fact I am learning all the while, improving things by building and listening! Some unexpected some not.It's a big learning curve and I think I am on the lower slopes!!!
HENRY
Old 21st August 2013, 07:48 AM   #306
which is also why I thought smaller stackable modules could be 'convenient'
by 'small' meant something like 7 x 12 inches
but also means you would have to repeat the same more than once
which does not seem like your favourite thing
Old 21st August 2013, 08:23 AM   #307
I have built a couple 12 x 8" speakers but the work involved is even more than building bigger ones, I am quite happy to build only 60 x 40 mm ones using neos and build slightly bigger ones using ferrites. This is the best way for me. Have built bigger ones 7' x 2' using neos. I am also interested in using cheaper magnetic tape having built one about 34" x 18". Which was a surprisingly good sounding design which was a big shock as I didn't think it would be, you live and learn. Still that's part of the enjoyment.
HENRY
Old 21st October 2013, 01:21 PM   #308
Default NEW DESIGN TRIAL
Have decided to try new design with about 3.9 mm gaps between the magnets, my son using some software worked out the gap size for improved sensitivity. We shall see, or not. Will use 3.9 mm wide plastic strips too keep the magnets apart. If this is a lot better, it will mean a lot more re-builds and more magnets to build more speakers. Wish me luck, and keep your fingers crossed, my back doesn't give in!!!
HENRY
Old 21st October 2013, 03:23 PM   #309
tyu is offline tyu  United States
Henry.....................keep pushing a long for us all......thanks for your info....
Old 22nd October 2013, 09:55 PM   #310
Default BUILDING TO COMPARE GAP AND NO GAP BETWEEN MAGNETS
Using 50 x 12.7 x 3 mm Neos with 3.9 mm gaps between N & S.
HENRY
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 01:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 10:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 05:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 08:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 07:38 PM
