Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 24th February 2013, 09:22 AM   #241
geraldfryjr is offline geraldfryjr  United States
The neo's you have are 1/3 the thickness of the ferrite's and also nearly 1/5 the volume as well for each magnet.
This could be why the big difference in the sensitivity!!!
FWIW
jer
Old 24th February 2013, 09:53 AM   #242
JarreYuri is offline JarreYuri  Sweden
Now I think it's time to clear some physical facts before You give unqualified tips to people.
There are significant properties that makes neo magnets much better.
One of them (and that is the major) is that You WILL get higher efficiency from the speaker using them
The plain physical fact is that they have MUCH higher magnetic flux then ferro magnets.
Jamesbos... You really need to rethink Your magnetic layout on Your speakers as You do it ALL WRONG with magnetic collapse as a result.
Cheers!
The one who succeeded was the one who didn't know it was impossible.
Old 24th February 2013, 10:57 AM   #243
brian t is offline brian t  United Kingdom
brian t's Avatar
would you care to elaborate on whats wrong with his layout.cheers
Old 24th February 2013, 11:07 AM   #244
First of all, You should never ever put the opposite poles side by side so that they make contact.
That will ruin the whole design idea as the magnetic flux will direct itself immediately to the magnet touching next to it.
So N should NEVER EVER touch the S on the same plane.
Cheers!
Old 24th February 2013, 11:10 AM   #245
I think this is the basic that all should know and I give You this tip for free because I care.
Cheers!
Old 24th February 2013, 08:29 PM   #246
gootee is offline gootee  United States
Good point. Several people have suggested that a gap should be left between the columns of magnets. I think they had other reasons, ie either to leave area for air to move or because it would enable the use of fewer magnets.
But it seems reasonable to believe that if the N and S were touching, the field would almost act like there was a short, there, and not as much would extend out to the mylar.
So that leads me to believe that for a particular distance to the mylar, there should be an optimal spacing for the N and S columns, that would maximize the field stength in the plane of the mylar, where the foil is.
Old 24th February 2013, 10:48 PM   #247
WrineX is offline WrineX  Netherlands
WrineX's Avatar
yeah always leave space in between the North and South poles, this is where ur foil runs on the mylar, this is the reason why magnepan uses allot of rows of small magnet strips in the lenght of the speaker so you can run allot of foil or wire in the gaps. this layout is not verry usefull when you have big magnets, take another look at the epsilon layout everywhere the foil should run there must be a gap between 2 magnets atracting one another, but dont let them touch eachother. the closer together the higher the fields strength. remember that the sound needs to go out of the speaker to so dont go smaller then gap of 1 mm (and be sure there are holes in the metal in this gap or the sound just bounces against it instead of going into ur room). for instance if you put an esl against the wall all ur low end and allot of the Sensitivity will be gone!
So the gap is importend for 2 reasons.
Try to create a layout where you get the most length of gap out of ur magnets, so you can use as much coil so ur mylar is driven as uniform as possibble.
arange magnets like NORTH SOUTH NORTH SOUTH NORTH SOUTH ETC between north and south you let the foil run up the speaker and with south north back down again just repeat it.
dont mess that up or some of ur foil will be playing out of phase canceling the other sound so you wil end up with nothing, or far less.
Old 25th February 2013, 02:16 AM   #248
At least the wire/foil placement versus the magnet poles can be easily verified, by using a piece of wire and a DC power supply (with a resistor in series).
Old 25th February 2013, 07:38 AM   #249
JAMESBOS is offline JAMESBOS  England
I have to rebuild all my neo speakers as well, now I am using 3 mm wide tape, more pain for the old back. I know neos are stronger than ferrites, I have the blood blisters to prove it!! After building over 60 full range planars of all sizes and layouts I think I know what I am doing by now. The secret to sensitivity is using all the magnet area you can. Which I aim to do with all my re-re-builds. I am confident I will increase sensitivity quite significantly with the same number of magnets. I did build one with gaps between the magnets, but gave up the idea, as the magnets were unstable even with super glue, and there wasn't any improvement in sensitivity, worth the extra work involved. As I said the 60 x 40 using ferrites is 8 Db more sensitive than the large 4' x 2' one using neos, which I already know are much stronger. The important difference is in the foil layout. The opposite is true when you just use the normal layout of putting the foil over the intersection of the N & S. If this makes me unqualified so be it!!
HENRY
Old 12th March 2013, 09:28 AM   #250
Default some more reduced pictures
some more pictures with new covers, canvases quite cheap.
HENRY
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 01:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 10:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 05:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 08:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 07:38 PM
