Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 18th October 2012, 09:54 AM   #221
JAMESBOS is offline JAMESBOS  England
Default MORE NEO REBUILDS.
more!!
HENRY
Old 18th October 2012, 09:59 AM   #222
Default and more
I no longer use the epsilon layout too much work for little return.
HENRY
Old 18th October 2012, 10:03 AM   #223
Default and more
ditto
HENRY
Old 8th November 2012, 05:01 PM   #224
EternaLightWith is offline EternaLightWith  United States
Send a message via AIM to EternaLightWith Send a message via Yahoo to EternaLightWith
Default thickness of mylar
I was looking at regular mylar and the metalized mylar.
The thinnest is 0.9 - 1 mil which converts to 24 micrometers (microns).
Maybe I missed it, but how thick is the mylar itself?
Earlier in the thread Henry was talking about 12uM , which I assumed was referring to the thickness of the aluminum tape.
Anyone have ideas on mylar/aluminum coating thickness? I was thinking you'd have to take in account the thickness of both layers, if going the metalized mylar route.
Sincerely,
David P.
Edit: Was reading http://www.magnetostatic.com and he said the thickness of both aluminum and mylar was 12uM which together is 24uM which does equal 1 mil thickness. So I guess the assumption could be made that 1mil (24uM) thick metalized mylar is 12uM/12uM mylar/aluminum.
Last edited by EternaLightWith; 8th November 2012 at 05:07 PM. Reason: opps it's henry not james
Old 5th January 2013, 11:24 AM   #225
Default Upgrade of covers and repair caused by old age and senility
Replacement of ruined diaphragm and new covers for hanging full range planars.:-
HENRY
Old 5th January 2013, 11:29 AM   #226
Default THE NEW COVERS
The new cover ready to be hung after repair. 2 more to do but problem with the one over the door size wise. Not made my mind up yet what to do!!
HENRY
Old 5th January 2013, 11:38 AM   #227
The original covers of differing shades of blue, will make good dust covers!. The canvas pictures are more in line for married men! You could give her the choice of picture, this will help if you have problems with your better half. The pink dhalias look nice.!!
HENRY
Old 5th January 2013, 11:46 AM   #228
Default DE-CLUTTERING.
Will be removing large ferrite uncovered ones, less clutter so I can do more measuring, when I have sorted out software to do so! Any tips would be appreciated.
HENRY
Old 5th January 2013, 11:54 AM   #229
The actual canvas covered speakers sound better, not so harsh, which seem to be a trait of the neo magnets I have found. Or it may have something to do with the size, although I have built larger neo ones, which still sounded harsher than the larger ferrites. The ferrites do sound more mellow and not as strident!?
HENRY
Old 5th January 2013, 12:06 PM   #230
SEdwards is offline SEdwards
There is probably a rising response if the diaphragm is really lightweight.
I think that Room EQ Wizard has it covered for frequency response graphs, and is free and unrestricted. I use the demo of ARTA to check distortion.
Do you already have a mic?
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 02:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 11:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 08:38 PM
Copyright ©1999-2017 diyAudio
