Planars & Exotics ESL's, planars, and alternative technologies
Full range planar speaker using neo magnets
Old 25th May 2011, 10:18 AM   #91
JAMESBOS is offline JAMESBOS  England
Default SOME BETTER PHOTOS.
Better photos with titles, will be covering all the bare speakers as I have plenty of material. Just what to put where!?
HENRY
Old 16th June 2011, 03:52 PM   #92
Default 9.2 SYSTEM UPDATE.
Have finished covering my 9.2 full range planar speakers! Using the sewing machine was harder than building them, and more frustrating. Breaking threads all over the place, glad I have finished them Have still got more rebuilds to do mostly ferrites. Will be putting some more videos on utube. When I have found all the different music off my cards!Will be playing some piano music, as this is one of the hardest to reproduce correctly!!??
HENRY
Old 1st July 2011, 09:02 AM   #93
Default 9-2 Amp parameters
Could spend the rest of my life trying all the different parameters available with my new 9-2 Amp. But I don't have enough patience to do this or time left!? I wish there was an automatic program you could run on your computer which would do it for you!!
HENRY
Old 1st July 2011, 06:59 PM   #94
pikkujöpö is offline pikkujöpö  Portugal
Hi
Nice man cave you got there Henry!Always nice to follow your thread.Maybe someday in the far future I will be able to build some kind of planars...
xxx I should correct my spelling xxx
Old 1st July 2011, 07:41 PM   #95
karellen is offline karellen  Spain
Originally Posted by pikkujöpö View Post
Hi
"man cave", Hell I like that name! i will have one, but still not dare... and Im still married...
I don't like to die before building my own planars
nice work
Sure Henry is the "planar man"
A cold amp is a sad amp... I like them warm at least
Old 2nd July 2011, 12:05 PM   #96
Thank you both for your kind words, I am lucky that I live on my own so I can do what I like, lucky me!!! I know its a big problem when you are married. They are very hard to please, at the best of times. Still you could always turn them into pictures with a very nice subject to please the better half! Or get a big garage in the garden and put them in there! The 60 x 40 mm is a very good size, you get good bass as well. As I said there just the right size for most hiding and disguising situations. Better than the large APPOGEE and MAGNAPAN sized speakers and a lot cheaper as well.
HENRY
Old 26th July 2011, 11:20 AM   #97
Default LATEST REBUILDS
latest rebuilds will follow when I can get the uploading to work or is something changed
HENRY
Old 28th July 2011, 02:33 PM   #98
boiss is offline boiss  Italy
Default Pole pieces
Hi, just a thought, instead of using so many magnets why not use neo 50s
but instead of 1k use only 100 with pole pieces attached. There would be some reduction in the field but it would still be much better than ferrite strips.
Cheers
Boiss
Old 28th July 2011, 08:47 PM   #99
Default LATEST REBUILDS FERRITES
The holographic ones are the latest rebuild and the blue ones are the next. They were both doubled up ferrites and very heavy. Have used the 23 micron membrane with the thinner width alu tape. This makes them more sensitive and very much lighter and frees up more magnets for other designs. The MDF is the new frame for the blue speaker. The white one is the old one made out of an old wardrobe door so was free. The magnets have been re arranged in a single layer. Doubling up the magnets was a complete waste of time and magnets, for no benefit whatsoever.
HENRY
Old 14th August 2011, 04:35 PM   #100
trondareo is offline trondareo  Norway
trondareo's Avatar
Could one use copper tape 5mm wide like this
I´m doing stuff at http://taooftubes.wordpress.com/
Full range planar speaker using neo magnetsHide this!Advertise here!
my 14 inch full range speaker! chinese Full Range 235 21st September 2010 02:30 PM
Where to find magnets???For Diy Planar floydturbo Planars & Exotics 8 27th July 2010 11:28 PM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 06:13 PM
full range speaker for HT Jazzz Full Range 13 8th September 2006 09:27 PM
beginner full range speaker tacomaboy Full Range 5 12th January 2004 08:38 PM
