Planars & Exotics ESL's, planars, and alternative technologies
power demands
power demands
Old 18th November 2006, 01:32 AM   #11
stokessd is offline stokessd  United States
stokessd's Avatar
The HV supplies use very little power, my switching supplies use about as much light as a nightlight for the pair. It is possible to make a circuit to turn them off, but to me it's not worth the expense of building the circuit. My electricity is about $0.10/KW-Hr. I'd guess that the circuitry to turn the supplies on and off is about $50 for a pair if I am frugal and clever. At 7 watts, that is 71,428 hours to payoff. That is over 8 years; too long.
My DIY esl's play well using a pair of 20 watt amps, they are pushing it a bit with 10 watt amps. My 20 watt amps use tubes which aren't very efficient, but they are only on when I'm listening to music.
Everything I own plugs in, and my electric bill is still quite reasonable, so I don't sweat it too much. I do turn off light when leaving rooms, but I don't stay up at night thinking about it.
Sheldon
Old 18th November 2006, 01:49 AM   #12
stokessd's Avatar
Originally posted by JinMTVT
you guys talked about shutting down the high voltage on the diaphragm when not in use
can you propose a simple effective way to make an auto on and off circuit to extend the life of the unit ?
i have seen such auto much times on subwoofer plate amps ..
Yes, you would start with a little power supply that is on all the time (oops, we defeated the purpose). then you'd have a connection to your audio input that would drive a high impedance stage (op-amp) set up as an active rectifier. The rectified audio is smoothed (integrated with a cap) and sent to a comparator. the output of the comparator changes state when the musical signal exceeds a threshold. Now the logic of the circuit: There should be a very long time constant RC circuit (this is the ghetto way) that either charges or discharges over a very long time. When the comparator changes state is restarts the RC decay process. If the RC circuit (think 555 timer here) decays past the timer threshold, then it turns the HV off. When the RC is reset, the HV supply turns back on. The real problem with this concept is that the many minute RC time constants can be flakey when they age (the board gets dirty etc).
the cheaper and easier way to go is to have the rectified and filtered audio signal go into a PIC microcontroller that does the checking and timing.
The big problem with turning off the panel is that many panels take a while to charge up. So you aren't listening to a properly functioning panel for a while.
The real issue here is the circuit to turn off the panel will use roughly as much power as the original power supply does. Defeating the purpose if you want to save electricity. Just pull the plug, it's cheaper and easier.
Turning off the power o the panel can slow the accumulation of dust and dirt in the panel. That can be a good thing, but it's easy enough to vacuum out the panel every year or so. I have never had a problem leaving my panels on all the time.
Sheldon
Old 18th November 2006, 03:00 AM   #13
moray james is offline moray james  Canada
Default Why not...
the simple oscilator circuit that uses a resistor in parallel with a cap feeding a neon bulb? Simple and works Quad uses them. Regards Moray James.
PS I hope that the intent was not to actually shut the supply off to save energy. This will only decople the diaphragm from the supply which is more important.
moray james
power demandsHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
headphoneamp with demands.. Mr. Triatic Solid State 10 20th April 2005 10:24 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
