Planars & Exotics ESL's, planars, and alternative technologies
Monsoon planar drivers - has anyone used 'em?
Old 14th October 2006, 09:04 PM   #1
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Default Monsoon planar drivers - has anyone used 'em?
I'm trying my hand at building speakers. Although I am still working on my first pair, I'm already shooting for my secod. (Stupid? Yes.)
For the sake of simplicty, I was looking at the Monsoon planar satellites, used in their line of computer speakers, usually with a woofer. I heard that they're pretty flat down to 1k, at which point I would cross them over to a woofer, likely mounted in a transmission line. Alternately, I could use a fancier crossover setup, but I figure that simply bi-amping the whole thing would make it easy and cheap.
Can anyone make any reccomendations for a matching woofer? I would'nt mind something for near-field listening (about 1.5 meters), and I live near Madisound, so one of Audax's more inexpensive woofers might work well. (And Madisound has some as low as 10$!)
Old 14th October 2006, 09:44 PM   #2
dwk123 is offline dwk123
I have 3 sets of the 'big' monsoon planars that were used in the MM-1000 system. Unless you're looking for insane levels, you should be able to get down below 1000 - remember that they were crossed at 200Hz in the computer implementation. I certainly wouldn't suggest using them that low, but 500-600 should be worth investigating.
I had some pretty good results using them in a cobbled-together waveguide (search over at HTGuide), but have never gotten around to trying them in a conventional arrangement. IMHO they sound very good within their limits.
For near-field you want to stay small-ish since integration is an issue, and try crossing at about 500 - nearfield this should be OK. Almost any reputable ~6" driver will be fine up to 500, and provide OK bass for nearfield music listening. Something like the Adire Extremis or the Tang Band knockoff would be ideal, but even the Dayton RS180 will have tons of output for nearfield and will sound great.
I don't have any direct experience with any of Madisounds current offerings, unfortunately. If you can get an Audax aerogel unit on closeout, though, they are supposed to be excellent.
Old 16th October 2006, 11:22 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Which TB are you referring to?
planet10 needs your help:
Let's help Ruth and Dave
Old 17th October 2006, 01:05 AM   #4
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The big planars have a panel resonance below 200 Hz. They go down flat to 1k where you start getting dipole roll-off (which was countered with EQ in their multimedia sets). If you mount the planar in a larger baffle it will remain flat lower (ie a baffle 4x the width of the planar should get you to 250 Hz -- that is where i plan to XO mine).
I've actally got a collection of parts that will allow me to triamp 2 big planars + 2 small planars + a woofer on each side. Woofers are MM700, planars are MM1000 mid/tweeters and MH502 planar tweeters. mid & tweeter amps supplied by some MM500 boards (i'll only ise 2 of the 5 amps on this board allowing me to use dead on one channel amps. The only diy will be building baffles & wiring it all together so it works (i'll have to add diodes & filter caps to the Planar Media 9 power tranformers, but i can salvage those parts too)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th October 2006, 01:56 AM   #5
dave
Fancy selling me some?
Old 18th October 2006, 02:28 AM   #6
I was thinking of the 6.5" long throw that bears a resemblance to the Extremis. - W6-1139. I've never actually used it, but my thinking is that nearfield where effeciency isn't a huge concern, the excursion would allow more flexibility for eq'ing for more extended low end.
Old 18th October 2006, 08:19 AM   #7
frugal-phile(tm)
planet10's Avatar
I've smoked thru all the big panels (probably went thru 150 panels). I have a few tweeters left and woofers from 4" to 8". Lots of transformers & boards that are "condition unkown". Plus my personal stash (i might be talked out of those -- given the number of projects in the queue, loosing a few wouldn't hurt)
dave
Old 18th October 2006, 08:52 AM   #8
dave
150 panels? Woah!
I could probbably use some of the tweeters - they should work okay with inexpensive Audax mid-woofers from Madisound.
That, or you could sell me the "fancy pants" panels, which would also rock.
Old 18th October 2006, 04:28 PM   #9
Speakerholic
Cal Weldon's Avatar
Hi dwk,
I think you'll find those two are very different drivers. The Extremis can be used in a stand alone two way, the 1139 cannot IMHO. It requires an external amp and has no midrange. Not even the big Monsoon planar would be suitable as a complement. I would go for the Extremis for sure.
Both are very good at what they do but wouldn't be considered for the same project.
I am using the TB 1139's with 8" PR's.
I have a dual Extremis in a sealed box.
I use the big Monsoosn planars with the proprietary woofer. At least I think it's the one that came with the system. We'll have to ask Dave to confirm that. They came from him.
Old 18th October 2006, 05:47 PM   #10
frugal-phile(tm)
planet10's Avatar
Cal got both MH502s (2.5" + planar tweeter & 4" woofer) & Planar Media 14 systems (big panels + 8" woofer).
We had the opportunity to buy out the left overs from the North American service depot. Most of the parts went out as complete systems, i got to sell off the excess/spares.
The similarity between the Tangband and the Extremis likely arises because they are built by the same OEM. The Extremis is unique and the only 7" woofer i know of that thinks it is a 10".
dave
Monsoon planar drivers - has anyone used 'em?Hide this!Advertise here!
I fixed buzz in Sonigistix Monsoon planar magnetic drivers Andersonix Planars & Exotics 35 12th August 2013 07:27 PM
monsoon planar media 7 as line array vmps Planars & Exotics 24 5th September 2009 06:23 PM
monsoon planar computer spkrs capt mike Planars & Exotics 4 29th July 2008 10:05 AM
Small Monsoon-planar speakers - any help! Spasticteapot Multi-Way 0 5th January 2007 08:23 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 11:59 PM
Copyright ©1999-2017 diyAudio
