Planars & Exotics ESL's, planars, and alternative technologies
Induction planars
Induction planars
Old 16th August 2006, 07:28 AM   #11
phase_accurate is offline phase_accurate
Who was talking of magnetless drivers ?????
Charles
Old 29th July 2007, 10:35 PM   #12
APi is offline APi  Finland
Default Re: Double the Hifi?
Originally posted by misterears
A true magnetless induction transducer is unfortunately a frequency doubler since it has no way of discriminating the polarity of the induced field (which is why a permanent magnet is needed as a reference unchanging field).
True. But maybe it's possible to predistort the signal in the way that current through the coil follows the next formula:
a x V(t) = I x dI/(dt) , where
a = scale factor
V(t) = signal level as a function of time
I = current from PA ~ first magnetic field
dI/dt = derivative of the current ~ derivative of the second magnetic field
(dI/dt ~ induced voltage over almost constant resistance ~ induced curent ~ second magnetic field. )
I see this very hard to realize by analog predistorter since constant signal level cause more or less t^(1/2) shaped function for I. But digital... GNU Octave would be the easiest way to test such algorithms?
One other thing... To make system more effective one could generate more eddy currents by modulating signal with some sort of (triangle?) pulses above hearing frequency ~20kHz. Er....
Old 6th August 2007, 06:53 PM   #13
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
Or perhaps the driver would need some DC offset, Class A style.
Induction planarsHide this!Advertise here!
Help with Induction heating for steam jacob.jacob0 Power Supplies 16 7th February 2008 07:35 PM
PS choke magnetic induction Klimon Tubes / Valves 3 9th April 2007 09:45 AM
Papst Induction Motor. Paul Dimaline Analogue Source 3 20th March 2006 10:24 PM
Induction Compensation 2-way Filter Lars Clausen Multi-Way 3 4th February 2004 07:33 PM
Static Induction Transistors, SiC Mohan Varkey Solid State 0 3rd February 2002 01:25 AM
