Planars & Exotics ESL's, planars, and alternative technologies
Bass Ribbons
Bass Ribbons
Old 14th July 2006, 12:33 PM   #1
SQFan is offline SQFan  South Africa
Default Bass Ribbons
Hi All, has anyone come across a system that can handle bass down to about 40Hz without damage to the ribbon or audible distortion ? If so, i would like to find out a bit more on this.
Old 14th July 2006, 01:04 PM   #2
phase_accurate is offline phase_accurate
Not exactly bass but quite low:
http://www.getmad.us/
Charles
Old 14th July 2006, 10:08 PM   #3
LineSource is offline LineSource  United States
LineSource's Avatar
110db SPL at 40Hz for a monopole speaker requires 1,500 cm^3 of volume displacement.
A large planar magnetic speaker like the Apogee or Magnepan bass panel are currently used to reach 40Hz with reasonable SPLs. A 6' x 2' panel is 11,150 cm^2. These are dipoles and require even more volume displacement for deep bass, about 2,400cm^3 dipole displacement at 40Hz 110db would be a good estimate.
110db SPL at 80Hz for a monopole speaker requires 375 cm^3 of volume displacement. My bass ribbons are steeply crossed at 80hz since this is close to the limit of human voice.
Old 15th July 2006, 03:04 PM   #4
bear is offline bear
expert in tautology
bear's Avatar
Bass Ribbons
Among others, Apogee?
Making "pure" metal ribbons go down that low is a big problem.
Doing it with ribbon (metal) conductors on a substrate, not as much of a problem... unless you get huge ur not going to get super high SPLs compared to modern high power, high Xmax cone drivers...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 15th July 2006, 04:32 PM   #5
thadman is offline thadman  United States
how much excursion do ribbons normally have?
Old 15th July 2006, 07:20 PM   #6
jreitz is offline jreitz  United States
Default Planar Woofer
I made a planar woofer about 15 years ago. It worked awesome. It did not punch like a paper cone woofer because it was limited in excursion length, but it played very low. I used a frequency generator to sweep from 1-500 hz and it played audible bass all the way down until you could just feel it. I would like to do another one and supplement it with a 10" sub.
I have been talking about building some more ribbons for a couple years, when I get off my butt & do it I will post some pics for everyone. It's cool having a planar forum out here
Im trying to get my hands on a pair of apogee divas to hear what they sould like.
John
Old 15th July 2006, 07:20 PM   #7
Line source,
What kind of bass ribbons are you using? Did you build them?
Old 15th July 2006, 08:10 PM   #8
BillWW is offline BillWW  United States
Default Re: Planar Woofer
John
I have been into planar speakers for about since the early 90's.
I own a Apogee full range and my brother owns an Apogee Diva. I also own a Carver Amazing Loud Speaker Platinum ribbon/ hybrid.
My experience with dipoles are they have the most natural sounding bass of anything I have listened to including horn loaded low frequency bass horns.
The apogee were very quick, not quite as fast as my Khorn, but the panel sounded boxless with no anoying wood colored tones of a box that all boxes create. Even Wilson audio with their very dampened boxes just sounded like it sucke the musicality out of the frequencies.
Over all, I find panel bass sounds the most realistic just like a real Kettle drum in a symphony, because the woofers do not move a lot like this drum, but instead depend on surface area, which sounds the most realistic to me.
The Carver 12 inch aluminum woofers moved a lot of air. It seemed like they could move plus or minus 1 inch on their excursion. The problem with that was the Carver seemed very slow in comparison to the Apogee panel.
My brother built a 18" 4 per side panel subwoofer and found it was very fast. The trick is to use woofers that do not move a lot of air or in otherwords cheap woofers for a panel sub.
An alternative than a ribbon panel would be to use some aluminum 15", 12" or even 10" woofers. I think the aluminum woofers that would be nice for this project would be the http://www.partsexpress.com/pe/showd...number=295-368
I like this cheap 10" woofer, because it is very flat up to 500 or so Hz. It also seems to go down relatively low compared to the other 12 or 15 inch woofers of this Dayton reference series. I like their pole piece how it reduces distortion. I would down the road when I get enough funds to try maybe 4 to 8 10 inch woofers a side for a panel sub to mate with my midrange and tweeter compression horns.
I have found with the dipole panel, it has been difficult to do wide bandwidth, so I believe with this 10 inch reference woofer it would do both relatively well compared to other woofers out there. It is black anadized aluminum, which looks nice.
Bill
Old 15th July 2006, 08:17 PM   #9
Default 10" woofer
I just wanted to correct the above woofer goes up to very flat 800 to 900 Hz and not 500 or so Hz.
Regards, Bill
I forgot how high it went, but just looked at the pdf again of the specs.
Old 15th July 2006, 08:23 PM   #10
el`Ol is offline el`Ol  Germany
I would have an 18" air filter for airplains. If someone likes to build giant ribbons from the folded paper he would just have to pay for the shipping.
Bass RibbonsHide this!Advertise here!
Ribbons and Corrugator Marik Planars & Exotics 6 4th October 2005 12:59 AM
Ribbons - for interest clive@tsrg.net Multi-Way 3 14th August 2005 03:56 AM
Anybody know these ribbons? ronning Multi-Way 6 16th May 2005 06:56 AM
LCY-130 Ribbons Luke123 Planars & Exotics 1 15th May 2005 09:33 PM
'reference' speakers idea (ribbons & sealed bass bins) lucpes Multi-Way 38 5th July 2004 12:13 AM
Copyright ©1999-2017 diyAudio
