Planars & Exotics ESL's, planars, and alternative technologies
want to build a DIY ribbon, need suggestions
Old 1st June 2006, 12:46 AM   #1
thadman is offline thadman  United States
Default want to build a DIY ribbon, need suggestions
I am building a DIY ribbon this summer and would like some suggestions as there isnt much information out there (other than the few informative threads on here)
I'd like to build a ribbon that rivals the LCY 130 (horizontal and vertical dispersion) and a ribbon that is able to be crossed over comfortably with an 8
I'd like this to be a no-bars held project (ideal ribbon design, no compromises), as I have full access to CNCs, lathes and the like
Old 1st June 2006, 02:31 AM   #2
I have several connections and all of the magnets I recieve will be completely free...so the design is really open ended.
Old 1st June 2006, 03:15 AM   #3
LineSource is offline LineSource  United States
LineSource's Avatar
Hi thadman,
The DIY archives contain all the technical info you should need, with many well documented examples and helpful websites. You could proabably spend a week studying this material. You may want to give some consideration to a long ribbon linesource during your study.
Downloading the FEMM magnetic field simulation program will be valuable if you want to do a unique design instead of a clone.
N50 grade magnets are near the highest production stength. BIG is good.
Thin aluminum foil between 5 to 10 microns is commonly used by most DIY'ers.
Old 1st June 2006, 07:28 AM   #4
I've spent a week or so searching over the forums for diy ribbons and have learned a great deal, that is mainly why im attempting to build my own.
Do longer ribbons have any difficulty producing the higher frequencies?
Would I have issues if I ran the ribbons dipole and the midbass-midrange (50-1000/1200) monopole?
Is there any optimal ribbon width or length where you start to meet diminishing returns?
Is the main goal of a ribbon to create the most powerful uniform magnetic presence in the gap?
Old 1st June 2006, 07:28 AM   #5
I have to check with my distributor, but the highest ive found was N55.
Is there any benefit to using below 5 micron aluminum (I know LCY uses 6 micron and an average aluminum wrapper is around 15 micron)? Are there any other types of material that are good, light weight conductors that are candidates for ribbon use?
Old 2nd June 2006, 05:22 AM   #6
LineSource's Avatar
A small area ribbon is capable of producing the highest frequencies, well over 50Khz, but you may need to add a waveguide or horn to get the room SPL you desire. A well designed long tweeter ribbon can easily reach 30Khz with well over 110db SPL in most rooms. I've posted the simple equations for ribbon efficiency several times in the archieves.
I favor running the tweeter ribbon as a monopole to reduce short delay reflections that can "falsify" the sound stage. Dipole designers like Linkwitz also favor monopole tweeters. A monopole ribbon tweeter requires extensive absorption material in the rear cavity. Some like the "spacious" presentation of a dipole tweeter. Some describe dipole sound as "you are there" to explain the synthetic ambiance from upper fequency rear reflections. "They are here" is a pharse often used to describe the performer centric soundstage of a good monopole speaker. Some claim that dipoles offer more degree of room tuning than monopoles. Dipole vs. monopole midrange/midbass is like religion.. you will have to try both and decide for yourself.
The ribbon width will set the upper frequency both as the wavelength approaches the ribbon width, and because wider width adds mass while the gap magnetic field goes down.. a squared affect. There are equations to determine the minimum ribbon volume sweep to generate the desired SPL in your room. A full floor-to-ceiling is the other extreme.
The main goal of the motor design is to create the most powerful and uniform magnetic field in the gap. One can experiment with many different ribbon construction options to get the pharsing they like best. Just like two musical instruments.
Ribbon efficiency increases with lower mass, but AL foil below 5 microns if very fragile. Magnapan uses a 2-2.5u tweeter ribbon which is 0.2" wide. You can read AudioAsylum notes to judge how robust it is.
The archives describe mylar-aluminum ribbons which some find smoother sounding and more robust. You can get aluminum sputtered onto mylar or polyimide(take a capacitor apart), or glue AL to mylar as described in the archives.
Old 2nd June 2006, 09:21 PM   #7
how efficient would an 8 foot ribbon be?
Im considering doing 2 ribbons for a 2-way
1 8 foot .25" ribbon (upper frequencies)
1 8 foot 2" ribbon (I'd like to get to 100-200hz with this)
Where could I purchase Mylar Aluminum ribbon?
Old 3rd June 2006, 03:21 AM   #8
LineSource's Avatar
The simple ribbon efficiency equations have been posted several times in the archieves. For a tweeter where excursion is not an issue:
A=ribbon area meter^2
B=magnetic field in Telsa
%= percent of ribbon which conducts current(100=100%)
m= mass of ribbon in grams
Efficiency = A^2 * B^2 * % / m
spl 112.2 + 10*(LOG(efficiency)/LOG(10))
senS effeciency + LOG(8/resistance)/LOG(10)
For a +/- 0.1" maximum excursion a monopole ribbon would reach max SPL of 110db at 420 Hz. A dipole ribbon would reach max SPL of 110db at 320Hz. The original Full Range Apogee speakers had a 2" wide x 84" long midrange ribbon that was crossed at 320Hz to the bass panel.
Check the archieves.. especially Swedish ribbon, and take apart a film/foil capacitor.
All the info you need to clone these ribbons is in the archieves. The FEMM program will allow you to create a unique design, or optimize the iron-magnet motor circuit
Old 3rd June 2006, 05:06 AM   #9
how bad is the horizontal dispersion of a 2" wide ribbon?
Old 3rd June 2006, 05:50 AM   #10
LineSource's Avatar
2" is a wavelength of ~ 6,775 Hz. There should be very little beaming if you cross a 2" ribbon below 3,385 Hz, AND have a well designed front bezel or waveguide to remove pole edge diffraction, plus large radius cabinet corners.
The design of the pole pieces, rear cavity, absorption material, front bezel/waveguide will have a large affect on the on-axis as well as off-axis sound stage.
want to build a DIY ribbon, need suggestionsHide this!Advertise here!
10" MTM with NeoPro5i Ribbon - Build Thread opc Multi-Way 128 30th August 2011 11:16 PM
Need some suggestions on what to build. morphon Full Range 14 17th November 2008 05:05 PM
Ribbon tweeter/mid suggestions craigwalsh Multi-Way 13 1st November 2008 09:36 PM
WTB: Aluminum Foil For Ribbon Build valveitude Swap Meet 8 6th July 2007 03:21 AM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 08:33 AM
