Planars & Exotics ESL's, planars, and alternative technologies
Toroidal mains transformer
Old 29th March 2006, 12:55 PM   #1
bigwill is offline bigwill  United Kingdom
Default Toroidal mains transformer
I have a toroidal mains transformer lying around. I want to use it as an audio step-up transformer just to test my experiments, I know the quality wont be very good. Will this blow up my amp? My load will probably have a low capacitance and I will not be driving it very hard, I just want to get sound. I'm unsure of the ratio of the transformer but it has two primary leads and four secondary leads so it must be a dual secondary step down transformer. I will drive the secondaries with the amp and use the high voltage output across the primary (I don't need a center tap at the moment). Is there anything particularly wrong with doing this?
Old 29th March 2006, 01:24 PM   #2
On Hiatus
SY's Avatar
Whether or not your amp will blow up is one of those unanswerable questions until you try it. That's part of the fun and adventure of DIY.
For an ESL, you do want a very high step-up ratio, so parallel the secondaries and use the primary as the ESL drive. What are you planning to do about the needed center tap? Are there dual primaries, too? That would be ideal.
One thing to watch for is insulation failure, so if you see or hear any sparks, smoke, or what-have-you, be ready to do an emergency shut-down.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 29th March 2006, 01:38 PM   #3
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
If you can put a one ohm power resistor in series with the sand amp and the transformer for the initial testing you will make it easier on the amplifier.while finding out generally if your idea is going to work or not.
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Old 29th March 2006, 02:17 PM   #4
I guess I could tap a battery to the terminals to get sound but that's not as fun as music
Old 29th March 2006, 02:32 PM   #5
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Watch here :
http://www.diyaudio.com/forums/showt...t=new+trannies
Old 29th March 2006, 07:39 PM   #6
bobo1on1 is offline bobo1on1  Netherlands
Default Re: Toroidal mains transformer
The sound quality of those transformers is pretty good.
If you don't drive it with more voltage than the transformer was originally designed for you can be sure your amp won't blow up.
Old 29th March 2006, 09:18 PM   #7
Hrm, $4.00, that's pretty insane. Shame they're out of stock. I wonder what the equivalent thing is here in the UK
Toroidal mains transformerHide this!Advertise here!
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 10:35 PM
Toroidal transformer for F1 milezone Pass Labs 7 24th September 2009 10:23 AM
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 12:04 PM
how to swich toroidal to mains, HELP juanito Chip Amps 5 21st January 2007 07:24 PM
WTB:toroidal transformer sma Swap Meet 1 3rd February 2004 01:21 AM
