Planars & Exotics ESL's, planars, and alternative technologies
Manger SWING
Manger SWING
Old 26th March 2006, 03:03 PM   #11
el`Ol is offline el`Ol  Germany
Originally posted by Tenson
Looks good. So come on then, what are the disadvantages of this driver?
What is its power handling like?
A disadvantage is that most amps don`t deliver enough current for the 13Ás rise time. A friend of mine tuned his power amps with large mica impulse capacitors in the power supply. Breathtaking performance.
Old 27th March 2006, 10:00 AM   #12
phase_accurate is offline phase_accurate
One has to watch out not to mix things up. The rise-time has nothing to do with current delivery (or better: current consumption). Current consumed is a function of impedance and driving voltage.
Rise-time is also affected by impedance (namely inductance) but other factors as well.
The Manger is almost resistive only, with a very low 16uH series inductance which is an easy load for almost any amplifier.
If you don't use an amp with high bandwith (Manger recommends > 150 kHz) you don't have any disadvantages from the fast rise-time of the MSW but you don't get all of its advantages. Simple as that.
As far as disadvantages go, there are two that I can name: Somewhat higher distortion than other drivers and two "holes" in FR at 800 Hz and 1600 Hz.
But even though there are some things that others do better I wouldn't change to anything else at the moment.
Charles
Old 31st March 2006, 07:38 AM   #13
inertial is offline inertial  Italy
Hi again,
yetserday I've heard third audition with swing+subsonice.
Mmmmh, something of not perfect in the integration sub-sat.
But the 200Hz ---> up is "magic"!! Really amazing.
I have suggested to my friend to ask the little zerobox bookshelf
to the distributor, but at the moment they do not have " in-house".
I' m very curios to listen it...
Inertial
Old 31st March 2006, 03:32 PM   #14
Jeroenkv is offline Jeroenkv  Netherlands
I would suggest at least two subwoofers!!
Old 31st March 2006, 03:53 PM   #15
Hi, Yeroenkv.
Yes, you are right.
But from the moment that one swing plus two subsonice(manger also)
costs about 8800 euro, my friend want to try the little zerobox bookshelf ( 3400 euro).
Again I am skeptical about the very low ( 90 Hz) x-over freq suggested from Manger : my ears hear something of not correct. Just my opinion
of course.
Inertial
Old 31st March 2006, 04:31 PM   #16
You can also do it the DIY way. Buy a pair of Mangers and Vifa woofers and use the filter & building plans from their site.
Old 31st March 2006, 05:02 PM   #17
Oh, the speaker isn't for me, is for my friend!!
He is a bit "snob", and like "trade" , signature, etc.
But I have the opportunity to listen and comparate (to my DIY) the best loudspeakers he can test.
And this is very important, IMHO.
regards,
Inertial
Old 15th April 2006, 01:28 PM   #18
max653 is offline max653  Russian Federation
Hi guys
Can be will recommend for me the driver for subsonice in a pair to MSW.
Wanted to purchase two scan_speac 25w_8565_00 but it seems model have removed from production. Can there are best variants?
The paper is desirable
Sorry for my English
Old 15th April 2006, 03:35 PM   #19
Hi max653,
The original woofer of the subsonice is a VIFA 10" ( custom I believe).
regards,
Inertial
Old 15th April 2006, 05:31 PM   #20
rick57 is offline rick57
Default fast rise time
Charles
What are the main determinants of fast rise time, in order?
What amps (eg around 50 watts) would have a very fast rise time, the Aksa 55?
Manger SWINGHide this!Advertise here!
6J5 input swing lndm Tubes / Valves 11 29th December 2006 10:47 PM
Q on voltage swing JoshK Tubes / Valves 4 13th December 2006 08:11 PM
how much above B+ will voltage swing in OPT? AudioGeek Tubes / Valves 2 15th April 2005 05:17 AM
Not enough voltage swing in P3A amp ?? Stormo Solid State 1 30th June 2003 09:02 AM
How to swing (for those skilled in the art) Circlotron Everything Else 1 4th December 2002 01:51 AM
Copyright ©1999-2017 diyAudio
