Planars & Exotics ESL's, planars, and alternative technologies
A DIY Ribbon Speaker of a different Kind
Old 8th July 2018, 08:08 AM   #1241
ndhennin is offline ndhennin
Thank's for the answer Solhaga !
You have answered to more than my question, great !
I stupidly forgot that the coil has to stay in the flux coming from the iron all the time, so i do not have to bother about the flux between the magnet.
Now, i also know that there is no need for the iron to "over hang" the magnets.
Another question, with such a high flux you are getting with your motor and the small thickness of your iron plates, and a 3mm gap, nothing bends ?
Old 8th July 2018, 09:04 AM   #1242
solhaga is offline solhaga  Sweden
I would say that a 20 mm wide iron bar will bend.
Depending on how long it is of course.
That´s why I use 40 mm by 5 mm bars.
Downside is that it will require double the amount of magnets and of course result in a wider motor.
Some pictures of making my simple motor above:
Iron bars and aluminium stops::
Ready for the first magnet:
That was easy:
In its right place with some epoxy:
As the next magnet will repel, I need a mounting jigg:
Next magnet must have the right polarity.
If I hold it in my hand, it will will flip right.
And then just force it down:
Some epoxy before the final destination:
Now I will have to wait a couple of hours before the next magnet can be mounted.
The tricky part will be when I mount the two legs of the motor together.
I'm thinking of using rails and then slide the two parts together and then --- BAAM!
Old 8th July 2018, 02:58 PM   #1243
i don't know if i am the only one, but i can not view your pictures
Old 8th July 2018, 03:47 PM   #1244
I'll fix it.
Fixed?
Old 8th July 2018, 04:30 PM   #1245
Yes, thank you
Old 13th July 2018, 06:55 PM   #1246
Well.
Front down:
Front mid:
Front up:
Back down:
Back mid:
Back up:
2,69 mm is too little, I'll probably have to insert 3,5 mm spacers or even 4,0 mm.
On the other hand, I can insert an additional spacer between the mid (210 mm) and treble membranes (80 mm)
Old 14th July 2018, 04:49 PM   #1247
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Originally Posted by solhaga View Post
Well, just for the fun of it:
But the plot was the same as above:
Even it can be tweaked to a higher or wider field, I guess it isn't worth the effort neither design nor build wise.
i did not know you where into these to 0r only sims
Old 14th July 2018, 04:51 PM   #1248
WrineX's Avatar
That was easy:
yes 20mm will bend with that kind of magnet i had a few bending with only 40x20x1 magnets over a length of 500mm steel
Old 14th July 2018, 05:28 PM   #1249
I will eventually start a new thread when I have got a little bit further with my Rubanoid, meanwhile I only answered the FEMM question from ndhennin.
Old 21st July 2018, 10:50 AM   #1250
WrineX's Avatar
looking forward, since i want to do some more ruba to, they are even more efficient then the AMT. most certainly with that HUGE motor.
A DIY Ribbon Speaker of a different KindHide this!Advertise here!
Ribbon Bookshelf Speaker LineArray Multi-Way 2 6th June 2008 11:38 AM
What kind of laptop to analyze speaker ostie01 Multi-Way 2 27th December 2005 07:18 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 10:12 PM
What kind of speaker design is this? Keith TDI Multi-Way 8 25th March 2002 03:56 AM
