Planars & Exotics ESL's, planars, and alternative technologies
Direct drive amp schematic
Old 11th December 2005, 02:30 PM   #11
Calvin is offline Calvin  Germany
Calvin's Avatar
what I´ve listened to is without any relevance for the prob.
ESLs work by voltage not by current. It would be practically impossible to build a constant current amp for the whole audio band.
Calvin
Old 12th December 2005, 10:50 PM   #12
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
I have an idea to take regular driver IC and use it to drive high voltage transistors.
It is possible , and would this schematic work ?
Lukas
Old 13th December 2005, 04:13 AM   #13
el`Ol is offline el`Ol  Germany
Here is a discussion about Class D with thyratrons.
http://www.diyaudio.com/forums/showt...threadid=69538
Old 13th December 2005, 08:25 AM   #14
Calvin's Avatar
@Bazukaz
It won´t work with this schematic, because the output Trannies work as Buffers with an voltage amplification of ~1. Therefore the driver circuit (the IC) has to supply all the needed voltage which it doesn´t.
The thing could work with added circuitry, that steps up the low output voltage of the IC to the desired high level. But adding steps means adding probs with phaseshift and stability and..and....and........
jauu
Calvin
Old 13th December 2005, 04:03 PM   #15
hilbren is offline hilbren  Netherlands
http://www.headwize.com/projects/sho...ilmore_prj.htm
http://www.ultranalog.com/
- http://ultranalog.com/9912/9912.html
- http://ultranalog.com/9912/phylira2.html
- http://ultranalog.com/9912/p25/
- http://ultranalog.com/coldwar/
(only problem with this schematics is; i don't see ANY feetback??)
can anyone give me a gues of the price of one of those schematics?
Old 14th December 2005, 09:04 PM   #16
Bazukaz's Avatar
I think that direct drive amps are generally better then output trannies.
Transformer gives much more distortion than amplifier itself.
ESL's are very efficient.Almost all power is dissipated in amplifier.
So , a new type of amplifier that could use this feature of ESL is required .
I don't even imagine how such an amplifier should look like ...
Direct drive amp schematicHide this!Advertise here!
ESL Headphone direct drive Bazukaz Planars & Exotics 22 28th April 2012 10:07 PM
ESL Direct Drive Atom666 Planars & Exotics 6 5th October 2008 08:09 AM
Direct Drive fun!!! Cobra2 Analogue Source 32 20th January 2007 02:23 AM
Another direct drive thread maudio Planars & Exotics 18 25th June 2006 06:53 PM
ESL Direct Drive SS amp jgwinner Solid State 34 30th August 2004 06:42 PM
Copyright ©1999-2017 diyAudio
