Planars & Exotics ESL's, planars, and alternative technologies
More Linaeum?
More Linaeum?
Old 12th December 2005, 07:20 PM   #11
moray james is offline moray james  Canada
Default wel
Dan: if you can find a set of Sumo Aria's or either of the Museatex Melior speakers (the small floor standers were the best of those two) you can have a flat planar that uses a point source driven panel. The Highwood Audio driver (uses in those speakers) uses a high strength tight gap motor assembly to drive a 1.25 inch voice coil fixed to the centre of the diaphragm. If you want to build your own you can use a very good mid driver motor and augment the top end with a tweeter. To get the bandwidth we had to use a lot of tweaks on the motor assembly. If you find a damaged set of any of the Highwood Audio speakers I can provide you with a new set of voicecoils.
I should think that a nice line source could be made with available neo magnets and some iron pole plates. If you took the Linaeum idea and uses some ferro fluil in the gap to help stabilize the voicecoil you would have a very nice driver. Play around and see what happens. I also think that a good 360'ish degree driver could be made with the same Lineaum idea with a slightly stiffer diaphragm formed into a cylinder with one vertical end of the diaphragm clamped and the other vertical end of the diaphragm attached to a voicecoil being driven like a single ended Lineaum. Hope that makes sence. Regards Moray James.
moray james
Old 12th December 2005, 08:04 PM   #12
dstockwell is offline dstockwell  United States
Originally posted by D Brummitt
dstockwell:
Good luck with DIY electrostats but watch those volts! HAve you tried substituting the cone drivers in the Radio Shack units with something different, better ... doping the originals ... x-over mods & etc. Am sorely tempted to go after my LX-10s.
Dan B.
I really would not know where to start, I guess I could go over to the loudspeakers forum and start there, or open them up and take a look.
More Linaeum?Hide this!Advertise here!
Linaeum Tweeter - Please Help johnobuttons Multi-Way 21 14th December 2008 05:14 AM
linaeum tweeters ET-6A SGD Planars & Exotics 7 7th May 2008 02:47 PM
diy linaeum tweeter larc99 Planars & Exotics 1 22nd January 2008 06:54 PM
Where is Linaeum Tweeter goldyrathore Multi-Way 25 20th May 2004 06:02 PM
Copyright ©1999-2017 diyAudio
