Planars & Exotics ESL's, planars, and alternative technologies
Please rec. step-up transformers for ESL
Old 7th October 2005, 11:43 PM   #41
Lucius is offline Lucius  United States
Thanks for the tips Calvin & I_Forgot. I have a lot better understanding on this topic.
Lucius
Old 9th October 2005, 02:22 AM   #42
moray james is offline moray james  Canada
Default Super tweeter ESL
Here is a link for a super tweeter ESL good up to 110 KHz.
http://www.tdt.com/Modules/EC1_ES1.htm
Regards Moray James.
moray james
Old 19th October 2005, 02:09 PM   #43
Emiel is offline Emiel  Europe
Hi all!
I've been reading this thread (actually this complete forum) with great pleasure and interest and it has convinced me of building a pair of ESLs in the near future.
But some questions remain, of which one is in line with this thread, and I hope you can help me with this:
You guys here are talking about using 'normal, step-down' toroidal power transformers. The only toroidal power transformers of about 50VA Amplimo has (I prefer to use Aplimo because of my good experience and I can get them at a fairly good price), has two secondary windings and one primary. The lowest secondary voltage is 2x6V. Can use two of those trannies and get the previously stated ratio of 1:75? If yes, how should these be wired?
Kind regards,
Emiel
Old 19th October 2005, 05:42 PM   #44
Calvin is offline Calvin  Germany
Calvin's Avatar
Default connection
You can use two trannies. Connect all 4 6V-Windings in parallel and the two 230V windings in series with a center tap.
jauuu
Calvin
Old 19th October 2005, 05:45 PM   #45
furly is offline furly  Canada
Send a message via MSN to furly
Default Spacer thickness?
Hey Calvin,
I am just curious here, What type and thickness of spacers have/would you used for midrange speakers that are crossed with bass units?
furly
Old 19th October 2005, 06:22 PM   #46
Calvin's Avatar
Default spacers
spacer thickness should be chosen after frequency range and filter response. Roundabout 1mm (40mil) for frequencies from 150Hz/>12dB
or 200Hz />=12dB. I wouldn´t go down further since the panels width would have to become really big. Too, as soon as the diaphragm has to ´move´, distortion goes up significantely. As long as You keep beyond 200Hz distortion levels keep extremely small and dynamic headroom is more than plenty for HiFi. Efficiency can be quite high, because of the small spacings. All voltage levels ...wether it are the polarising- or the signal-voltages.... are quite low. Such panels can be driven with lower transformer ratios because they don´t need several kvolts to sing. Polarising voltages around 1.5kV and signal voltages of a couple of hundreds volts are enough. Which reduces the risk of corona and other undesirable effects of higher voltages.
spacer materials can be various sorts of plastic material that can be glued to the stator and the diaphragm. Try to get pure material, because You never know the ingredients of coulored stuff. Avoid grey or even black material because there may be carbon in. Take care about constant thickness of the material. Some clear acrylic material can vary quite much. Use material with a small dielectric constant. In Germany You can get a clear plastic foil (1mm thick, 1m wide) off of the roll in every DIY-market.
Easy to use are the foam-Tapes by 3M. They are quite costly, but spare time and nerves. You even can get them in a clear version, which is quite interesting with regard to optics (but use those only as supporters to the diaphragm and not as a mounting frame!)
jauu
Calvin
Old 19th October 2005, 06:27 PM   #47
What is your opinion on a 3M tape with a thickness of 45 mil?
Old 19th October 2005, 08:25 PM   #48
Calvin's Avatar
Default Tape
thickness is ok. Use it if its the right tape
jauu
Calvin
Please rec. step-up transformers for ESLHide this!Advertise here!
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
Microphone transformers as step up. toufu Analogue Source 1 13th May 2009 10:42 PM
step up transformers neil_kaye Analogue Source 17 27th November 2007 08:56 PM
Bring me up to speed on step-up transformers. ak_47_boy Planars & Exotics 10 13th November 2006 02:18 PM
ESL step-up transformers for sale blu_line Swap Meet 1 7th September 2006 06:07 AM
