Planars & Exotics ESL's, planars, and alternative technologies
Please rec. step-up transformers for ESL
Old 2nd October 2005, 10:23 AM   #21
Calvin is online now Calvin  Germany
Calvin's Avatar
Default Toroids 1_40
simple toroids
Old 2nd October 2005, 10:24 AM   #22
Calvin's Avatar
Default EI-Types 1:100
audio EI-Types 1:100
Old 2nd October 2005, 12:36 PM   #23
dstockwell is offline dstockwell  United States
The panels I am considering would be overall 6" X 48" with usable 5" X 47" so I am not conceened with operation below 200HZ or so. Would the Hammond 125E be sufficient for output trannie.
Old 2nd October 2005, 01:20 PM   #24
Calvin's Avatar
Default Hammond
donīt think itīll work good. The 1650-Series looks better to me
I have come across the Hammond Site quite often, but I donīt think that they have the right stuff for ESLs. I miss serious data, You can work with.
jauu
Calvin
Old 2nd October 2005, 07:51 PM   #25
BillH is offline BillH  United States
BillH's Avatar
Hehe, I was all ready to order four of these toroids and then I saw this power transformer. 120/240 volt primary and 9 volt at 2 amp secondary in a cute little package. Does cute count?
From the spec sheet:
The twin primary and secondary windings are wound on separate bobbins giving maximum isolation for enhanced safety and low capacitive coupling. The near circular shape of the transformer core results in low magnetic flux leakage.
All transformers are subjected to 4.4kV ac insulation tests and manufactured to VDE 0550 Class 2, BS415 Class 2 and Insulation classification E 120 degrees C.
Does the 'low capacitive coupling' and 'low magnetic flux leakage' give any clue that these would suffer from the same drooping high end that Calvin has seen with audio transformers?
Edit: Grammar
Old 5th October 2005, 07:31 AM   #26
moray james is offline moray james  Canada
Default great info! something more?
Hey Calvin: great to have the benefit of your transformer experience. Wonder if you could comment on possible step up transformers for the super tweeter project I discribed? Would it be possible to obtain response to up to 100K with ultra thin diaphragm (2 micron) and the right transformer (not custom made)? Figure 1/2 to 3/4 inch wide diaphragm and 6-8 inches tall (rough numbers) with the diaphragm split into two vertical sections and a vein (vertical) to keep one side from interacting with the other. Spacers at about 1/32 inch thick. Thanks for the assistance regards Moray James.
moray james
Old 5th October 2005, 11:43 AM   #27
Looking at PP output transformers from Endcor however they only have 4 or 8 ohm taps not both, which one 4 or 8 would be best.
Old 5th October 2005, 04:19 PM   #28
bjackson is offline bjackson  United States
I have been following this thread for awhile, but I am a bit confused by a few things, and I hope someone can help me.
If there is a 8000 ohm to 4 ohm transformer what is the transformer ratio? Surely it's not 2000:1
What is a good source for the 220v to 9v toroid transformers I have heard of here?
And finally, if someone can answer this I'd be most grateful:
Can someone recommend a pair of transformers for a single ended amplifier that have atleast a 1:100 ratio, have decent phase and freq response, I don't need more than 15 watts of power handling (it's for headphones). Price for the pair must be less than 100 dollars, but preferably much less?
Old 5th October 2005, 04:57 PM   #29
furly is offline furly  Canada
Send a message via MSN to furly
question 1:
turns ratio is found by sqrt(T2/T1)
therefore sqrt(8k/4) = 1:44.7
question 2:
The source mentioned above is a good one. You won't find these toroids around any cheaper.
Old 5th October 2005, 06:55 PM   #30
Can you explain or show how to wire those transformers.
Please rec. step-up transformers for ESLHide this!Advertise here!
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
Microphone transformers as step up. toufu Analogue Source 1 13th May 2009 10:42 PM
step up transformers neil_kaye Analogue Source 17 27th November 2007 08:56 PM
Bring me up to speed on step-up transformers. ak_47_boy Planars & Exotics 10 13th November 2006 02:18 PM
ESL step-up transformers for sale blu_line Swap Meet 1 7th September 2006 06:07 AM
