Planars & Exotics ESL's, planars, and alternative technologies
Electrostatic speakers, real ones and...Martin Logan
Old 18th September 2002, 12:22 PM   #11
peterr is offline peterr  Netherlands
peterr's Avatar
I remember seeing this picture before somewhere...
As far as I remember it is a diy project using the panels of two Quad esl57 speakers per side.
Keep an open mind. It helps.
Peter
Old 18th September 2002, 06:08 PM   #12
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
That could well be it -- stacked quads done right. I only have a non-captive tweeter panel, but the style is definitly the same.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th September 2002, 09:38 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As an amusing side note, Wuti Larn, then of Landec Labs in
Menlo park, worked with ML originally and recommended
a good coating, but they chose to go with the graphite.
The result was a 100% failure rate after some years. It
is a tribute, however, to Gayle Sander's astute marketing
that this issue never became public due to his very
generous replacement policies.
Old 19th September 2002, 12:12 AM   #14
MRehorst is offline MRehorst
MRehorst's Avatar
I have seen photos of ML's assembly techniques in some of their sales brochures. One of the things that jumped out at me was the use of what appeared to be polyfoam tape, sticky on both sides, used to support the diaphragm (the horizontal strips you see every few inches). Does anyone know if that is actually what they use? That tape is an absolute disaster- it usually dries out and crumbles within a year or so of application.
Maybe they didn't worry about the diaphragm because they knew other things would fail long before the diaphragm...
MR
Old 19th September 2002, 01:00 AM   #15
gilid is offline gilid
Yes, they use a high-density foam tape, both for the horizontal supports, as well as the edges of the panesl. The construction is:
metal stator|double sided adhesive foam tape|mylar diaphragm|double sided adhesive foam tape|metal stator
On my CLS's, the foam core of split due the stresses imposed by the panel curvature - this did not really affect sound quality significantly, but it makes you question their design practices.
In spite of all that, the CLS is a superb speaker.
Old 19th September 2002, 01:08 AM   #16
specialx is offline specialx
Account Disabled
Hi on the topic of ESL's I have a few questions if anyone would care to help.
Firstly, with high/low resistance diaphragms 'gilid' mentioned 100Kohm resistance. Now I have been following this page regardin ESL's, http://www.amasci.com/esloud/eslhwto.html, and they say also 100Kohms, but make note that the resistance is measured using two pennies placed on the film a few inches apart, and then using a digi-multimeter. Would commercial speakers be around that or do they measure resistance differentl? Also is it bad to have too much resistance, say, 400Kohms or 1Mohm even? Or would you just have to bump up the bias suppies power? If that is the case, why not just use a high condutive material for the diaphragm and use a low power bias supply? (I am no electronics/physics genius so please excuse my questions if they aren't logical)
Regarding the semi-conductive coatings also, I did a bit of research on conductive inks and came up with this page
http://www.conductivecompounds.com/products.html
Down the bottom they have the C-100 product which is a resistive ink and when mixed with the AG-500 product (a conductive ink) you just balance it out to get the specific resistance/conductivity required. They even say it can be used for audio speakers, which I assume they mean ESL's. Has anyone heard of using this method of conductive inks or done it themselves? If so what kinda success if any was had?
Last question, ESL amplifiers. Are they different than an ordinary amplifier or is it just market hype?
Old 19th September 2002, 01:21 AM   #17
The actual film resistance is not very critical, as long as it is high (>100K) A lower resistance would cause the charge density to shift around over the surface of the diaphragm, leading to uneven performance, and stress on the psu.
I do not know how various manufacturers measure it, but the penny technique sounds reasonable.
The ink idea sounds good - the best way to find out if it works is to try it!
Regarding ESL amps, yes, they are very different from standard amps. A true ESL amp will drive the ESL panel directly, negating the need for the ESL powersupply. Such an amp needs to produce an output voltage in the range of several 1000's of volts (as opposed to 20-40 volts for a standard amp). They tend to be complicated, expensive and dangerous, so not too many companies actually make them. A company called 'Beveridge' used to make such an amp. I never had the chance to hear one, but they are supposed to be great - you eliminate a lot of components in the signal path.
Old 3rd April 2003, 06:14 PM   #18
aeronaut is offline aeronaut  United States
Send a message via Yahoo to aeronaut
[QUOTE]Originally posted by specialx
[B]Hi on the topic of ESL's I have a few questions if anyone would care to help.
The bias charge on the diaphram has very little to do with the resistance. If you take a standard resistor and apply some voltage to one end, leaving the other end open, in a negligible time the other end will be at the same voltage. This is true for a 5 Ohm resistor and a 50 MegOhm resistor (if they go that high.) The high resistance of the diaphram coating, as has already been pointed out, is to prevent the charge from moving around a lot while the speaker is operating.
From a physics point of view, if you consider the stators alone, there is no electric field between them when the speaker is not playing. They are both at some high voltage relative to ground, but there is no net voltage between them, so the potential (Voltage) between them must be zero, and the electric field, which is the gradient of the potential (measures the rate of change in space) is perforce zero also. This also means that with no audio signal, the only thing holding the diaphram in place is the tension from the sides. Without that tension, the diaphram would be free to move anywhere between the stators. I'm ignoring edge effects in this model, but that's a very good approximation, because almost all of the active stuff of the speaker is in the bulk, and not on the edges.
The reason that there is a resistive coating on the diaphram is that it has to carry some charge, or the speaker wouldn't work. Think of this resistance as being a poor conductor. Now, the film itself is an insulator, so you couldn't really store much charge in a uniform way on it. Personally, I don't think that the resistive film needs to be very even. Any conductor, even a resistive one, will have any electric charge that is on it evenly distributed around a uniform surface. Corners will get charge concentration because of boundary effects, but a flat resistive sheet will have an almost completely uniform charge density on it, even if there are inhomogenities in the resistance. This is all for static situations; I haven't pondered the deeper ramifications of the speaker while it is playing.
aeronaut
Old 4th April 2003, 05:56 AM   #19
stokessd is offline stokessd  United States
stokessd's Avatar
That's Wayne Piquet's work on Quads. He rebuilds them (after bombarding me with lots of questions to learn how). He's into different frames and lots of finish changes. Not my cup of tea, but style is subjective.
As to diaphragm resistance, most if not all modern ESL's charge the diaphragm through a high value resistor (10 - 100 megohms). This resistor is really responsible for maintaining constant charge operation of the panel. The panel resistance is measured in ohms per square. Square what? Exactly. It's non dimensionalized, and the two penny technique is good to test to make sure your diaphragm is conductive, but not really useful to reporting an actual meaningful surface conductivity value unless you factor in the penny geometry.
Simplification alert:
You can think of the resistance as part of an RC network of sorts. you want the time constant of the charge movement to be slower than the lowest frequency you want to reproduce for linear operation of the cell. so you could get away with a lot more conductive diaphragm in a tweeter than a bass panel.
As to foam tape, there are a lot of different grades out there. The eurathane foam with acrylic adhesive seems to hold up a lot better than the cheap grade foams. Your friends at 3M have a lot to say about foam tapes.
As to graphite: It's hard to get a more inert material to coat a diaphragm with than carbon. Back in my pupal stages, I used to use graphite to coat ESL diaphragms. It works well and lasts a long time in my experience (that CO2 argument strikes me as implausible). But it's tedious and tiring to apply and you can easily rip thinner diaphragm materials. There are easier to apply coatings whose surface resistivity can be tailored to whatever value you want. I use about 10^11 ohms/sq for quad ESL57 rebuilds, and about 10^8 ohms/sq for DIY esl cells and ESL63 rebuilds.
Electrostatic speakers, real ones and...Martin LoganHide this!Advertise here!
Martin Logan CLX distortion bolserst Planars & Exotics 6 12th August 2009 07:07 AM
amp for martin logan quest slr 5000 Pass Labs 2 8th June 2009 07:30 PM
martin logan's dsiroky Pass Labs 17 16th April 2007 11:13 AM
martin logan csl flodge Planars & Exotics 12 13th November 2005 03:59 PM
B&G NEO3 and NEO8 in Martin Logan speakers ?? cph2000 Multi-Way 3 7th March 2004 09:03 PM
Copyright ©1999-2017 diyAudio
