Planars & Exotics ESL's, planars, and alternative technologies
output trannies
output trannies
Old 3rd April 2005, 05:35 PM   #1
flodge is offline flodge  United Kingdom
Default output trannies
Hi I am a little confused about the arrangement for using two audio trannies. The sowter website says to ground the centre tap which is surely the bias connection. Is the problem that there is lack of clarity over the secondary and primary labelling. I suppose that a tranny designed for esl's might be labelled differently
Old 4th April 2005, 12:40 AM   #2
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Default Here ya go
With two transformers, whether or not they have center taps, you wire as shown. The primaries can be connected in series or parallel, whichever works best for your transformers and ESL panels.
I_F
Old 4th April 2005, 05:26 PM   #3
many thanks indeed
I have googled and found references to the concept and had worked out a possible connection in my head but the sowter web site threw me. Cheers for going to the effort of posting a schematic
Steve
Old 20th August 2005, 02:40 PM   #4
Pwoida is offline Pwoida  Australia
In the lower picture posted above by I_Forgot, if an impedance of Z ohms is connected between stators A and B and each of the transformers has a turns ratio of 1:n what would the input impedance be (ie Z referred to the input) ?
Old 21st August 2005, 06:35 PM   #5
Calvin is offline Calvin  Germany
Calvin's Avatar
Default Impedance transformation
with an ideal tranny the input impedance would be Z/nē with n depending on the connection of the primaries.
series connected primaries.....factor 1:n
parallel connected primaries...factor 1:2n
So parallel connection gives double the output voltage of series connected primaries, but the input impedance is 1/4th of it.
jauu
Calvin
output tranniesHide this!Advertise here!
Thoughts on output PP trannies hurdy_gurdyman Tubes / Valves 20 26th January 2010 01:03 AM
preamp with output trannies. then_dude Tubes / Valves 6 13th October 2006 05:06 PM
Bryston output and driver trannies, what are they? tubenut Parts 9 11th February 2004 10:19 AM
Possibly fake Sanken output trannies (PIC) capslock Solid State 18 30th August 2003 02:42 PM
DIY Output Trannies smoking-amp Tubes / Valves 8 30th March 2003 07:29 PM
