Planars & Exotics ESL's, planars, and alternative technologies
ESS AMT 1 impedance controversy...
Old 18th February 2005, 12:24 AM   #1
Urloony is offline Urloony  United States
Default ESS AMT 1 impedance controversy...
I have read here among the threads that the measured impedance of the AMT 1 series the "great heil" is about 4 ohms. However, I keep hearing about some AMT 1's that are 8 ohms. I have a pair of AMT 1's and the measured DC resistance is about 6 ohms. Is it possible to have a 4 ohm AMT with a measured DC resistance higher than it's impedance or do I in all likely hood have 8 ohm AMT's? I've included the original graph I found posted here. To add to the confusion I called Orange county speaker repair , who sell replacement ESS AMT diaphragms and asked them the impedance of the diaphragm. The sales rep said they were 8 ohm as listed in their computer. When I asked her if she could double check she spoke with a tech who said they are actually 4.
So what gives? There's also this ebay item that claims his AMT 1 is 8 ohms.
Old 18th February 2005, 10:37 AM   #2
Gregm is offline Gregm  Europe
Is there no way you can measure your amt1s? The impedance will be frequency dependant anyway and you want to know what it is at the chosen x-over frequency. The nominal value is an indication only...
The graph you attached shows impedance varying b/ween ~3,2-3,7 depending upon frequency, anyway, not 4ohm.
Cheers
Old 23rd February 2005, 03:56 PM   #3
JohnL is offline JohnL  United States
JohnL's Avatar
Ahh... that explains the blip at 1200 that I can't seem to get rid of. I thought the fs was around 800. In any event, my Great Heils (from an AMT 1B - old diaphrams) measure 3.9 Ohms with a meter.
BTW, have any of you played with the Eton ER4s. I just got a pair and can't wait to try them in something.
John
ESS AMT 1 impedance controversy...Hide this!Advertise here!
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
Has anyone been keeping up on the 'New Sensor' Controversy? aletheian Tubes / Valves 19 21st December 2005 10:17 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
the DVD format controversy Elkaid Everything Else 6 10th December 2003 12:58 PM
The controversy Peter Daniel Chip Amps 76 11th July 2003 11:21 PM
