Planars & Exotics ESL's, planars, and alternative technologies
OGIaudio - True Ribbon - Full Range
Old 9th February 2005, 02:23 PM   #11
OGIaudio is offline OGIaudio  Croatia
OGIaudio's Avatar
Thanks!
What is the resistance/impedance of the ribbon??
0.5 ohm ribbon
6 ohm speaker system
Old 9th February 2005, 03:04 PM   #12
dhenryp is offline dhenryp  United States
Originally posted by OGIaudio
Thanks!
0.5 ohm ribbon
I'm confused. I though the Ribbon WAS the speaker system. Wat is between the .5 ohm ribbon and the output of your amplifier?
Thanks,
Denis
Old 9th February 2005, 03:21 PM   #13
bear is offline bear
expert in tautology
bear's Avatar
Thanks!
0.5 ohm ribbon
Someone is being silly?
I highly doubt the veracity of the published frequency response curve is possible with just that little thin ribbon as the radiating element. OR, if it does then the max SPL possible has to be scary low.
The thickness spec'd in the post is ~10x the usual thickness for a tweeter, btw...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th February 2005, 07:02 PM   #14
OGIaudio's Avatar
What is between the .5 ohm ribbon and the output of your amplifier?
Please sorry, I can't tell you now.
My dear Bear...
Maybe for you will be scary low but for me is big enough.
You mean 0.0005mm. I want to see 2m ribbon with 0.0005mm thickness
What you want to say, you doubt in high freq. response of my speakers too?
Old 9th February 2005, 10:29 PM   #15
Paradise_Ice is offline Paradise_Ice  United States
Paradise_Ice's Avatar
Tomislav you have a very beautiful design, how do you get such impressive low frequency output from your ribbons?
I would love to hear those in action
Old 9th February 2005, 10:56 PM   #16
expert in tautology
bear's Avatar
So, then it isn't really "direct drive"??
My dear Bear...
I believe that the spec'd thickness of the Winey patent is 0.0005"
not mm... perhaps we have a metric vs. English units misunderstanding? I have no idea how thick 0.005mm is... hee hee...
But even so, you can't be getting much more than something on the order of ~80dB/1w/1m from them, right? Not with that bandwidth... and at around 90dB they'll try to rip themselves apart, no?
_-_-bear
_-_-bear
Old 9th February 2005, 11:30 PM   #17
OGIaudio's Avatar
Thank you, with big low resonance ribbon and big panels.
I don't use transformer.
NO
My ribbon drivers are very efficiency and they can be very loud on freq. above 100Hz.
Sorry, I don't know in numbers.
Old 10th February 2005, 12:07 AM   #18
Paul W is offline Paul W  United States
Paul W's Avatar
It is one of those translation things . I believe .005 mm = 5 microns...only about half the thickness of some commercial ribbons and about the lower limit for reasonable handling.
Old 10th February 2005, 01:37 AM   #19
LineSource is offline LineSource  United States
LineSource's Avatar
From my spreadsheets....some rough estimates and guesses....
A 2m x 17mm x 5 micron pure aluminum ribbon is 340.6 cm^2 area, 0.62 ohms, capable of 82db SPL @1m at 40Hz with +/- 4mm of excursion (+/- 0.16") on a 24" wide dipole baffle. Music has large peaks >10 db typical, and >20db for techno or 1812 overture type stuff, so the average listening level will be closer to 70db SPL @ 1m at 40hz
The 6 ohm impedance discussed could come from putting a 5.4 ohm resistor in series to make the load more amplifier friendly, or a series RLC equalization network that compensates for the dipole baffle width roll off
Old 10th February 2005, 07:55 AM   #20
OGIaudio's Avatar
Yes, you are right, maybe I have 6-7 micron alu. ribbon, it is difficult to measure.
Music has large peaks >10 db typical, and >20db for techno or 1812 overture type stuff.
Yes, my speakers works best with Jazz music, I can't listen loud a records with large low freq.
Maybe before I offer my speakers I will must put sub for freq. below 100Hz.
But I'm not sure which kind of sub system.
OGIaudio - True Ribbon - Full RangeHide this!Advertise here!
Halbach array for true ribbon tweeter. tade Planars & Exotics 4 22nd March 2010 01:19 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
Dual Concentric a true full range??? torontodude Full Range 13 13th May 2007 03:14 PM
Fountek True Ribbon Transducer krell Swap Meet 8 14th November 2004 08:37 PM
Copyright ©1999-2017 diyAudio
