Planars & Exotics ESL's, planars, and alternative technologies
Does hybrid dipole bass move diaphragm?
Old 2nd February 2005, 05:36 AM   #11
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
It occurs to me that one of the things that can be done to reduce the problem, at least in one respect, is to locate the mid-range and tweeter in low frequency axial standing wave nodes. I've never heard anyone talk about this thought before.
Old 2nd February 2005, 06:40 AM   #12
Stocker is offline Stocker  United States
Perhaps, but wouldn't there be various locations for the nodes depending on frequency?
Jesus loves you.
Old 2nd February 2005, 07:17 AM   #13
phase_accurate is offline phase_accurate
A little off-topic tough (since it is not dealing with ESL) but the mechanical stress on drivers by acoustical coupling is even relevant in the ara of tough professional equipment:
"For example, the horns attached to the driver act in both directions - not only do they transform and radiate sound from the driver to the outside world, but they also focus external sounds on to the diaphragm, adding significantly to its stresses."
Taken from:
http://www.meyersound.com/support/fo...op/drivers.htm
Charles
Old 3rd February 2005, 12:30 PM   #14
Pan is offline Pan  Sweden
If a closed box sub is used with dipole you simply place the sub at 90 degrees to dipole and voila, no problem from the direct outputoif the sub.
And with multiway dipole you need a gap between each range just like ML did it with their big speaker system.
The problem also exist with coned drivers as someone was concerned with, but the cone mass and enclosed volume beind makes this much less of a problem compared to a dipole ELS membrane.
By the laws of nature the mids and tweeters thast are most sensitive to this is of course those with soft suspension, low mass and big volume of air in the box behind. The stiffer the suspension, higher the mass and smaller the volume of air in the box the less this moving system will move according to a outside pressure acting on it.
Moving coil dipole speakers are more sensitive than closed box but less so than ESL.
In the end it is actually dipoles (no matter if moving coil, ESL or magnetostats) that can be arranged to be least affected by this phenomena, simply by doing it like ML. With perfect symmetrical dipoles and air gaps between panels there will be no force acting between the panels.
/Peter
Old 3rd February 2005, 05:11 PM   #15
Yes!
And while a boxed mid/tweeter would function best at a certain frequency node where the pressure is max and speed of air is minimum, the other way is true for a dipole velocity source.
Think about how dipoles vs. monopoles excite room modes... they do not do that in the same way and at same locations... food for thought.
/Peter
Does hybrid dipole bass move diaphragm?Hide this!Advertise here!
Hybrid Dipole Steve Cresswell Multi-Way 13 2nd November 2008 10:22 PM
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 08:42 AM
newbie needs help with dipole woofer hybrid esl CharlieM Planars & Exotics 4 26th February 2008 11:03 PM
ESL and Dipole hybrid system. christophorus Planars & Exotics 13 26th January 2004 10:18 AM
