Planars & Exotics ESL's, planars, and alternative technologies
experiences with ESL directivity?
Old 25th May 2018, 02:25 PM   #101
bentoronto is offline bentoronto  Canada
Originally Posted by bolserst View Post
...As much as I like to complain about Microsoft and Apple software, I believe that error is due to uninstalled service packs. The spreadsheet may work just fine even with the error...can't tell you for sure though. If you let me what version of Excel you are running, I can email you a copy saved for that version that should open up fine.
It is the recently no-longer-supported MS Office 2011 (and good chance some of us will not want any MS upgrades hereafter). I get some buggy messages from MS. Shoddy products, not up to Apple standards esp user experience.
Unlikely to have missing service upgrades.
No plans presently for me to use your generously provided app. Just helping fellow Apple fanboys know that Numbers will boot it. Pity about other sims.
B.
File Type: png Screen Shot 2018-05-25 at 10.15.22 AM.png (16.2 KB, 147 views)
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 26th May 2018, 02:22 AM   #102
Few is offline Few  United States
I received by email an alert that a thread of interest had a new post. I read it and thought “Yes, that really is right down my alley.” It took me a bit to realize the thread was familiar but ~14 years old. That’s quite a run! Thanks, Bolserst, for such useful updates!
Few
Old 30th May 2018, 05:22 PM   #103
blueocean is offline blueocean
Regarding the use of ESL_line_sectioned_DIY_v4 and esl_seg_ui: more the sections more the high frequencies with the asymmetric configuration 1?
In my case the wires are only 42 so getting double the central section is impossible....
with 9 (8 + 1) sections I set the nearest value that is: 10 4 4 4 4 or, with 11 sections 12 3 3 3 3 3.
another thing i noticed that if i increase the value of the resistors suggested by ESL_line_sectioned_DIY_v4 the results in esl_seg_ui improve, why?
Old 30th May 2018, 06:03 PM   #104
opps i correct myself, the result with different resistors don't improve, only fall the sensibility and that deceive my eyes.....
Old 1st June 2018, 05:30 PM   #105
played with the spreadsheet and esl_seg_ui in this week this configuration with seven segments (42 wires) seem to be interesting (with normal commercial resistors values...) it's a good starting?
Old 1st June 2018, 07:49 PM   #106
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by blueocean View Post
… i noticed that if i increase the value of the resistors suggested by ESL_line_sectioned_DIY_v4 the results in esl_seg_ui improve, why?
There is an interdependence of HF(high frequency) dispersion, SPL, and fL(low frequency break point) or bass extension.
As one would expect with mother nature, there are trade-offs in desirable characteristics.
Increase segmentation resistors: SPL is reduced, fL is reduced, HF dispersion is increased or improved
Decrease segmentation resistors: SPL is increased, fL is increased, HF dispersion is decreased or worsened
That attached set of plots shows response for fL = 100, 200, and 400Hz, by doubling segmentation resistor values.
You can see the trend in fL, SPL, and HF dispersion.
Old 5th June 2018, 04:14 PM   #107
bolserst's Avatar
Originally Posted by bentoronto View Post
It is the recently no-longer-supported MS Office 2011...
A version of the spreadsheet saved in post Excel 2007 format was sent and solved the import errors.
Thanks to bentoronto for reporting back results. If anybody else is having similar issues, let me know.
Have had a few PM on the topic of trade-offs in HF dispersion when trying to decide on number of segments and whether to use symmetric Configuration 1 or 2.
  • If your panel width and fL have been chosen, the dispersion will improve with increasing number of segments up to a point.
    Beyond that, further increase in number of segments does not improve the dispersion further for frequencies < 20kHz.
  • Configuration 2 needs only half the number of segments as Configuration 1 to achieve nearly the same HF dispersion.
  • Be sure to consider the output impedance of your amplifier when deciding which Configuration to use. In particular, it is not unusual for tube amplifiers to have output impedances of several ohms which will cause HF response to droop with Configuration 2 because it requires much lower series resistance feeding the central segment.
    Thanks to alexIG for identifying this issue.
Post with plots comparing polar response for different number of segments and configuration:
Thinking about a segmented wire stator ESL #39
Further posts on these topics:
Thinking about a segmented wire stator ESL #23
Thinking about a segmented wire stator ESL #79
experiences with ESL directivity?Hide this!Advertise here!
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity EQ Saurav Multi-Way 11 19th May 2008 02:41 AM
Constant directivity horn - or waveguide? hasselbaink Multi-Way 6 1st April 2008 01:24 PM
A question on directivity swak Multi-Way 18 31st July 2005 03:03 PM
Open baffles and directivity Yuihb Multi-Way 18 27th February 2004 08:22 PM
