Planars & Exotics ESL's, planars, and alternative technologies
Cardboard Speakers!
Cardboard Speakers!
Old 27th October 2004, 06:13 PM   #21
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Cardboard Speakers!
Well, this is the perfect group project.
Kind of the DIY reference speaker project- but so cheap that
everyone can participate!
The link shows lot of good xperimentation to this point- I wouldn'be a bit surprised if we could come up with something pretty darned good in the end.....
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 28th October 2004, 02:40 PM   #22
MEXXX is offline MEXXX  United States
Send a message via AIM to MEXXX Send a message via MSN to MEXXX Send a message via Yahoo to MEXXX
Well, no luck finiding the Sonic Impact T-Amp or the combo pack at my local Target.
There are two more stores within a 20 mile radius that I will check out this weekend.
I'm keeping my fingers crossed and hopes low.
MEXXX
Old 28th October 2004, 10:53 PM   #23
Sherman is offline Sherman  United States
MEXXX
The stores I found these at had them on the end caps in the vicinity of the stereos/mp3 players/computers. They were with a bunch of other clearance stuff and had no sign or anything on the shelves.
I'm in the far west suburbs of Chicago if that helps any.
BTW, I started to mod one of the amps today. I'm planning on putting it in an aluminum case with dual inputs selectable with a front panel switch and actual binding posts for speaker connections.
So far so good but I'm having a little troube de-soldering the LED. I don't want to overheat the surface mount devices so I'm being careful but it might be time to pull out the desoldering iron instead of using the copper braid.
Once that LED is off the board the rest should be a piece of cake (famous last words).
--Sherman
Old 29th October 2004, 03:47 PM   #24
marcusf is offline marcusf  United States
Hi;
Does anyone know if the small amp that comes with the flat speakers is the same type of chip as the class-T 15w amp? I picked one up yesterday and the documentation didn't say much about the amp except to state that it was 2 watts. I checked Sonic Impact's website, but it didn't say either. It sounded good through my fe127Es though.
thanks
Old 29th October 2004, 11:41 PM   #25
If your referring to this amp, no its not the same as the T-Amp.
Old 30th October 2004, 01:33 AM   #26
Originally posted by marcusf
Hi;
thanks
I don't know which class-T 15w amp you are referring to but the Sonic Impact that came with the cardboard speakers I bought is a 15wpc digital amp.
--Sherman
Old 30th October 2004, 02:15 AM   #27
To elaborate a little more on the specs its 6 w/rms per channel into 8 ohms @ 0.1% THD+N and 15 w/rms per channel into 4 ohms @ 10% THD+N.
Old 30th October 2004, 05:08 AM   #28
raintalk is offline raintalk  United States
Target and PE both sell this amp:
http://www.partsexpress.com/pe/showd...number=300-952
Looks to be higher power?
Old 30th October 2004, 08:43 AM   #29
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Cardboard Speakers!
Originally posted by johnnyx
I think those cardboard speakers used NXT technology
Yes, these are NXT distributed mode speakers. The cardboard is set to resonate by the exciter glued to the backside. Whereas we usually try to not have resonances in a speaker an NXT panel is designed to have as many resonances as possible, close enuff together that they have flattish response. (much much more info at NXT's website).
There is a page on these cardboard jobbies.
http://www.nxtsound.com/industries/i...es.php?f_id=16
A lot of research has gone into figuring out what shape, resonant qualities, and exciter position give reasonable sound quality. I doubt they will ever achieve real hifi, but they do some things like no other speakers can, and as your example shows, the box your cereal comes in could be a speaker (ie prize is the box not in the box )
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2004, 08:46 AM   #30
frugal-phile(tm)
planet10's Avatar
Cardboard Speakers!
Originally posted by Sherman
I did attempt to measure FR of the cardboard speakers this morning but couldn't. When playing a 1K Hz tone and setting the volume to 0 db on my meter I encountered a problem. At about minus 2 dB the speakers began emitting a second, completely different tone simultaneous with the 1K Hz signal.
That is a side effect of how they work... thet resonate.
dave
Cardboard Speakers!Hide this!Advertise here!
Free Cardboard tubes gengis Everything Else 4 5th August 2005 12:29 AM
cardboard can be cool Deagle50ae Multi-Way 14 7th March 2005 06:43 PM
Open baffle - from cardboard to... miguel2 Multi-Way 1 27th July 2004 04:55 PM
chocolate box cardboard coil formers :) Duo Multi-Way 4 4th January 2004 07:05 PM
Copyright ©1999-2017 diyAudio
