Planars & Exotics ESL's, planars, and alternative technologies
How low do they go -- JansZen ESL tweeter?
Old 22nd October 2004, 07:10 AM   #1
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default How low do they go -- JansZen ESL tweeter?
The subject gives the jist... i've a pr of the tweeters from a set of Z-500. Does anyone know where they were crossed and how low this ESL tweeter can go?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd October 2004, 01:58 PM   #2
inertial is offline inertial  Italy
(sorry for my english)
Hi planet10,
very interesting solutions on this ancient speaker!
( 1970-75, right?)
If I well remember , a similar ESL are used in the Wilson Wamm(!) ,
3or 4 units as a "medium" i suppose. I don't know exact specs. of the crossover frequency & slope but I suppose Fr 800Hz 12dB/oct H/P minimum, depends of the power handling target.
Can you take some measurements of it?
From the size I presume a behaviour similar to a BG neo 8 , in the same radiation conditions of course ( without "double" horn).
Good chances of beautiful sound
best regards from Venezia
Old 23rd October 2004, 02:05 PM   #3
On Hiatus
SY's Avatar
Ah, the familiar blue plastic! Radio Shack sold these for a while, too. They'll take a pretty hefty bias voltage.
I experimented with them some years back. JansZen never really got their crossover right, and no wonder- the unit really doesn't do well below 3-4K, then gets mighty beamy in the top octave. A tough match for a big woofer like they used. Arrays of them could probably do better, but I only had two.
I could see this in a dipole taking over from a full-range driver to cover the top octave and a half.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd October 2004, 05:44 PM   #4
frugal-phile(tm)
planet10's Avatar
Originally posted by SY
the familiar blue plastic! ... Arrays of them could probably do better
Black plastic actually on these. I had a set of 4 per side in the mid 70s...
dave
Old 23rd October 2004, 06:10 PM   #5
bear is offline bear
expert in tautology
bear's Avatar
Iirc, the practical LF limit is 1500 Hz.
They are not little "squares" they are actually [] rectangular lenthwise strips... as far as the internal cell construction.
I think 1500vdc is the practical bias limit.
They tend to fail where the center/diaphragm connection is.
They were graphite on mylar.
Once you get the bias too high they "fizz"...
They're not the cleanest ESL tweeters, and get worse the more you push them. Using a better *iron* for the matching xfmr might help in that regard. To replace simply measure the turns ratio and get some iron that is better with the same ratio...
Of course, with an ESL the ratio effects the relative sensitivity and the LF rolloff as well as the bandpass characteristic. So there is some yin/yang to play with in that area.
They were used in a number of notable speakers including the KLH ESL and cut in half in the Infinity Servo Static, later RTR adopted the 1/2 cell design in their blue tweeters...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
How low do they go -- JansZen ESL tweeter?Hide this!Advertise here!
Janszen Z-210a repair? Fmaker Multi-Way 6 15th February 2013 11:42 PM
Wanted - RTR or Janszen Panels Magnetar Swap Meet 0 23rd December 2006 12:30 AM
Janszen ESL re-born georgehifi Planars & Exotics 9 16th January 2006 05:47 PM
Janszen electrstat questions gothika Planars & Exotics 4 23rd April 2005 04:31 PM
JansZen Stat Tweets Thatch_Ear Multi-Way 3 26th May 2002 06:39 PM
Copyright ©1999-2017 diyAudio
