Planars & Exotics ESL's, planars, and alternative technologies
Tube amps and electrostatic speakers
Old 30th October 2004, 05:54 PM   #11
flemming is offline flemming  Iceland
It is ok to drive els with tubes. I have years ago build a 40W se amp. 2 parralled Svetlana 811-10 transformerdriven from 300B and 6SN7 srpp driver. The amp is driven at 1200V dc. The amp is not transformerless. The outputtubes drives a 1-2.5 centertapped transformer. To give the differentialdrive to the speakers. It works better than differential drive from the tubes. Less ringing and lower outputimpedance to get a better drive tin the high frequencies. My els is 40cm X 200cm and the capacitance is 1200pF.
There is no ringing on the drivesignal and the amp i capable to give out about 500V at 12kHz. I should be enough.
If you use tubes forget all about full output at 20 KHZ.
Before the se project i had an 6550 pp amp with 1 - 7 outputtransformer it had far to high outputimpedance. I modified it to 2-6SA7 regulator/outputtubes kl A driven at 250 V it works ok but much has much less power than the 811 amp.
I use the electrostatics to 300Hz, below that @-6dB a 10" speaker in closed boxes q= 0,5 and below 60-70 Hz @-24dB adjustable cornerhorn with 15" speakers. This systen is not rocking good at rockmusic but very good at symphonic orchestra and jazz.
Old 31st October 2004, 11:16 AM   #12
etalon90 is offline etalon90  Canada
etalon90's Avatar
An ESL need a lot of current if you want to acheive 20khz.
My esl (acoustat 2+2) are 1800pf per stator. At 20Khz, that represent 4.4kohm...
Esl need around 1000Vpeak-peak per stator for an appropriate listening level.
So the current needed for chargind the capacitance=1000/4400=227mA
How can you charge the panel if you have only 6ma avaible????
So the good thing is that in music, you never find a 20khz equal level compared to the rest of the spectrum... So you can divide this number by 2 or 3.
My amplifier will use 8 845 (4 parallel single ended, one for each stator). The current will be 160mA per output section (80ma per tube).
from calculation, I can hope -2Db at 18Khz at full output (2100Vp-p)
My output impedance will be approx 1Kohm
the stage will be like that. A 100% otl!!!
417A(rc)-->EQ-->10Y(lc)--> parafeed centertaped choke for phasesplit-->vt62(LC)-->845(rc).
I curently in the stage of buying the parts
Old 31st October 2004, 02:56 PM   #13
bear is offline bear
expert in tautology
bear's Avatar
Seems interesting!
Keep us posted on what the results are!!
Oh, are you going to drive the stators or the diaphragm?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 1st November 2004, 10:10 AM   #14
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
Martin, you are right, this is not possible.
This is also true, but i'm very shure that the division number is much larger than 3. Don't know howmuch, but it must be because when listening to an Acoustat X with the OTLamp there is nothing wrong with the sound. (on the original unit swap out the opamp for a TL074, which is better than the original opamp).
And the Acoustat X is made of 3 panels in parallel !
I would suggest to listen to one before judging.
In normal music the spectrum above 12kHz is besides hardly used, also much less in amplitude.
Hence, testing with test tones will not work with the mentioned SRPP, but music is no problem.
Ofcourse the described class A amp from Martin would work and sound very well, but it's a bit overkill.
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Tube amps and electrostatic speakersHide this!Advertise here!
Speakers for tube amps Hylle Tubes / Valves 33 1st May 2009 10:48 AM
FS: Speakers (Scan Speak, Seas Excel), Electronics (Tube Amps, Preamps) etc. PHilgeman Swap Meet 8 28th October 2008 02:22 AM
What speakers are good for tube amps?? Rob.capone Multi-Way 19 31st August 2007 12:32 AM
Speakers for tube amps... nickds1 Tubes / Valves 4 19th April 2006 01:15 AM
Tube amp and electrostatic speakers. Roger Tubes / Valves 31 26th November 2002 04:54 PM
Copyright ©1999-2017 diyAudio
