Planars & Exotics ESL's, planars, and alternative technologies
New Ribbon Speaker Technology -  Approach the perfect speaker?
Old 17th October 2004, 01:18 AM   #11
454Casull is offline 454Casull  Canada
http://www.transmissionaudio.com/ima...ve_Web_kHz.jpg
This looks hard to believe.
http://www.transmissionaudio.com/ima...se_Web_168.JPG
(censored)
Old 17th October 2004, 02:35 AM   #12
On Hiatus
SY's Avatar
454, I had to manually edit out your attempt to get around the obscenity filter. That's extra work for me (unpaid work!) and gets me cranky. Please don't do that again.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th October 2004, 04:08 AM   #13
Sorry.
Old 17th October 2004, 04:25 AM   #14
Chris8sirhC is offline Chris8sirhC  United States
Send a message via AIM to Chris8sirhC
So, after reading through the pattent application, im still a bit confused... What is actually different about these ribbons? It probably has more to do with my lack of understanding in how normal ribbons work.
Old 17th October 2004, 12:15 PM   #15
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Chris8sirhC - You're not alone wondering. I'm no ribbon expert either, but it sure sounds like he claims the prior art. There is something about an opening behind the ribbbon that may be novel, but it sure doesn't sound like the strongest patent application.
Then again, B*se seems to be able to patent the prior art pretty regularly.
Old 17th October 2004, 05:31 PM   #16
Ive seen a dipole ribbon before, so its not like that is anything new. The only other thing i can really gather is that on one of the designs the pole piece is inbetween the magnets and the ribbon (....I think???) and he doesnt have to use a transformer to drive it.
www.audiodesignguide.com/mag/index.html
Old 17th October 2004, 05:59 PM   #17
setmenu is offline setmenu
Interesting, I am a little baffled about how it is possible to achieve
a decent ribbon transducer with a ribbon width of 8cm without resorting to huge magnets or some planar arrangement?
My own limited ribbon transducer experience is designing a transducer for headphone use.
As for theirs being the first ribbon headphones ,I believe someone designed a pair in the 1930s and I had my first pair up and running in 2001.
Setmenu
Old 18th October 2004, 05:50 PM   #18
LineSource is offline LineSource  United States
LineSource's Avatar
Default Patent looks like Series Xover for Ribbons
The patent by TransmissionAudio that SY referenced appears to be an attempt to patent a series crossover for ribbons that is in common use for dynamic speakers.
Ribbons have a very low impedance, often < 1 ohm, and a step-up transformer is typically used to create a higher impedance between 4-8 ohms that most amplifiers can drive. This transformer inserts phase, step response, and frequency limitations. A good transformer is expensive.
By putting the midrange and tweeter ribbons in series, along with series passive components for crossover and equalization, one can create a higher impedance, more amplifier friendly load. This removes the cost and performance limitations of transformers, and allows one amplifier to drive multiple ribbons with greater fidelity and lower cost.
For long, wide bandwidth ribbons, I have found that a low impedance direct drive amplifier is required to mechanically control the ribbon's movement in the magnetic field. I have built Class-A amplifiers that sound very good driving a 0.5 - 1 ohm resistive load, which thanks to low 7V output power supplies, are modest in cost, heat and size.
Nelson Pass as part of his First Watt efforts has published a few articles on current source amplifiers and series crossovers that cover the same ideas as in this patent. Nelson has also discussed using a current source amp to drive (tweeter?) ribbons.
http://www.passlabs.com/np/CurrentSo...erNetworks.pdf
Old 18th October 2004, 08:52 PM   #19
woody is offline woody
Another new ribbon is made by BEEngineering and is featured
on www.E-Speakers.com down to 300hz! but do be seated
when you read the price.
Woody
Old 18th October 2004, 09:55 PM   #20
BobM is offline BobM  United States
These are the guys who made the ribbons for Mark Levinson's Red Rose speaker systems. In fact, if I read it correctly, they designed the entire Red Rose speaker line, not just a supplier of the parts.
Those speakers (especially the little one's) got a lot of nice reviews. So the new ribbons are better. Where's the project that proves that? And what's the cost?
Enjoy,
Bob
New Ribbon Speaker Technology -  Approach the perfect speaker?Hide this!Advertise here!
A new speaker technology GRollins Planars & Exotics 28 10th February 2009 11:04 AM
New Speaker Technology - The Future hifimaker Multi-Way 4 9th February 2009 03:39 AM
Technology Student Building Speaker morfius Multi-Way 13 8th September 2007 09:44 PM
the perfect speaker scottie2hottie Multi-Way 9 4th November 2002 03:10 AM
Copyright ©1999-2017 diyAudio
