Planars & Exotics ESL's, planars, and alternative technologies
Personal Monitor sized speakers : are ESL worth the troubles??
Old 9th September 2004, 04:51 AM   #11
JinMTVT is offline JinMTVT  Canada
i never actually thought that anyone was under any obligations in here
but i was kinda desperate to see 80 views and 0 replies
i think that electrostatics aren't quite popular around here!
well too bad..let's build some and have fun
Old 9th September 2004, 05:24 AM   #12
blu_line is offline blu_line
blu_line's Avatar
Default ohh, they are
Missed your post in the first place.
I build a couple of full ranges a while ago.
They do realy sound sweet ! The low frequencies are a trouble.
You proposed to have panels of 30x80 cm.
There is a width over length factor to achieve the best results.
And as i can remember it is 1:7 to 1:8.
A panel of 80 cm does not have to be 30 cm wide. 10cm Is mor likely !
you can e-mail me for more info/questions if you like !
grtz
Simon
Old 9th September 2004, 05:33 AM   #13
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Simon:
Actually , those of us (most of us? ) that don't know much about this would like to see your answers too!!!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 9th September 2004, 10:35 PM   #14
Default Re: ohh, they are
grtz
Simon
well i don't see why there would be a factor to keep at
just look at the almost perfect square 1950-60s ESLs ..
i think that people construct high ESL just for the convenience VS performance ..
it would be pretty crazy to build an ESL that is 8 feet high and 8 feet wide
my point wiht 30cm + wings is to push the dipole effects as far down as possible on the hz scale
10cm will definitly have to get corrected alot under 1KHz
i think ..and i do not wish to correct that much of it!
the lower end will be assured by a multiple driver sub setup
no problems here for me!
what kind of transformers u used?
polirazing voltage VS D/S ratio ?
i am trying to design a tensionned wire type right now..
might go that route, but with a completly different style from what others did !
for the transfos i've been looking at the ESL transfors from plitron
Old 10th September 2004, 03:16 AM   #15
Steve M is offline Steve M  Australia
Seeing I'm currently using various speaker technologies including Bass Reflex (Proac 2.5 clone & Fostex 206E in 20L cabinet); Infinite Baffle (expensive Yamaha NS1200 Monitors); Open Baffle experiments with Fostex & Raven ribbons; and Electrostatic speakers ( see the Mackinlay ESL-3 a kit spkr at www.eraudio.com.au ) .
I would recommend to any beginner that in order to get instant gratification - go for the Fostex 206E ($84USD ea A Madisound) in a 20L BR box ! You get elctrostatic-like sound without the cost, hassles of construction or size limitations. Also, the Fostex is a crossoverless point source driver that requires no tuning or tweaking for the beginner. You will need to sort out the bass later, which in my case is currently TL subs or a pair of 150L BR boxes with the superb Eton 11" hexacomb driver.
I have to say though that of the speaker technologies mentioned above, my favourite is the electrostatic Mackinlay ESL-3. It has lightning fast transients and leaves the others behind for sheer detail retrieval ... it's not perfect either, but to my ears and taste in music the best I've heard!
Just my two cents worth...
Steve M.
Old 10th September 2004, 03:23 AM   #16
more pics ...
Steve M.
Old 10th September 2004, 03:29 AM   #17
more pics...
Steve M.
Old 10th September 2004, 05:32 AM   #18
blu_line's Avatar
I used transformers from Final 1.03.
http://www.final.nl/
They sold left overs on a Elektor/Audio Event a couple of years a go.
I think, it has been a while, i used about 2mm, since i wanted a full-range.
Thats is what i have done. Took a lot of time to tension each wire.
I wanted to segment the stator and used a aluminium u-profile, with holes drilled in it at every 4-5 mm, to quide the wires.
Unfortunenatly the profile cut into to isolation and gone was the segmentation.
Take good care of the wire spacing, since this will influence your output tremendously.
grtz
Simon
Personal Monitor sized speakers : are ESL worth the troubles??Hide this!Advertise here!
golfball sized speakers (Sony DAV-IS10) markr89 Everything Else 0 14th September 2007 08:29 PM
Wireless In Ear Personal Monitor NeilKishar Everything Else 0 20th February 2006 10:22 PM
advice on a set of medium sized computer speakers Dr. Photon Multi-Way 13 11th May 2005 05:14 PM
