Planars & Exotics ESL's, planars, and alternative technologies
The "zero" ohm full range ribbon
Old 13th June 2018, 09:44 PM   #51
hellokitty123 is offline hellokitty123  United States
What about mylar with a complete ribbon slapped on it? Would that provide the dampening you spoke of?
Old 13th June 2018, 10:09 PM   #52
lowmass is offline lowmass  United States
no
you can still use the multi trace plastic and short all the traces together at the ends to get your low ohm
Apogee used a foil only 2 inch wide BUT its crossd over at about 3 Khz or lower to a 1/2 inch wide FO so it avoids the issue
Old 13th June 2018, 11:35 PM   #53
But you said 2 inch wide is best for low frequencies right?
Old 15th June 2018, 12:39 PM   #54
yes the 2 inch is better to go low but a 1 in will work too. The 1 inch requires you to get the gaps a little smaller and is therefore a bit harder to construct.
the last pr I built were 2 inch wide and only 30 inches long. They were in baffles 34 inches wide by about 38 inches tall. They played well down to 100 hz crossed to sub. But not to levels of a full floor to ceiling line
Also the short "line" of only 30 inches I dont like all that much as the vertical directivity makes a very small listening window.
Old 24th June 2018, 05:20 PM   #55
narkotic is offline narkotic  United States
Ah. Analysis Paralysis. As people are telling you constantly, start building something and "see what happens". This is a DIY site, after all, and most people here learn by using their hands.
You're trying to get someone to build you a "step 1, step 2, step 3" guide. I'm surprised you've gotten this far. I tried that before and just got ignored and shortly figured out why - it's a disservice to those trying to help as they started with their hands and then asked for help along the way.
The "zero" ohm full range ribbonHide this!Advertise here!
Helper Woofer(s) for "punchy" FAST/WWW/SAW/etc. to go w/ Fane 12" full range drivers sbcrx007 Multi-Way 227 8th January 2018 09:56 PM
1 "Foster FE103A Family" 4" Full Range Driver, Alnico Magnet, Made In Japan ~1968 cc72 Swap Meet 0 11th September 2015 06:57 AM
SB acoustics SB12MNRX25-4 "full range" Build thread wintermute Full Range 95 4th March 2014 09:15 PM
FS: Full Range Enclosures (19"w x 10.5"h x 12"d) axissilverhand Swap Meet 0 19th December 2010 12:01 AM
Full Range drivers - do they always "rip your ears off" at high volumes? chris661 Full Range 52 16th December 2009 08:25 AM
