Planars & Exotics ESL's, planars, and alternative technologies
The "zero" ohm full range ribbon
Old 13th June 2018, 04:31 PM   #41
WrineX is offline WrineX  Netherlands
WrineX's Avatar
well in that case i cant help you. read read read. if you suck now you can become better. if you are interested.... that is how it goes. i spended 80% of my free time towards ideas tests and so on. if you think you cant do it why ask. go read learn and try. if thats to much to ask why even ventilate the idea to begin with. since i see loads or hurdles that are not going to work. but if you go small and do it yourself you might learn something and change your idea to something that might be possible and even the best idea ever.. who knows.
Old 13th June 2018, 04:41 PM   #42
hellokitty123 is offline hellokitty123  United States
Trust me all I do is read. The biggest problem is always that the details I need are most often unclear and buried somewhere within mountains of forum pages. My time is limited and I have half a dozen complex projects I'm working on. Searching for obscure data on the internet is almost always a shadow chasing process.
There's a difference between coming up with a new design and copying an existing one without the details. I never said I "can't" do it I'm just trying to minimize mistakes and guesswork. I don't have a lot of money to work with.
Old 13th June 2018, 04:44 PM   #43
WrineX's Avatar
just build a small ribbon before you go any further. thats all im saying !. and you dont need help to search the forum. it has being done so many times. then and only then you will know if you can pull it off and if it is even aa good idea. just my 2 cents.. i always go small first
Old 13th June 2018, 05:11 PM   #44
Of course that's what I intend to do, I'm trying to decipher Lowmass's mylar ribbon explanation.
Old 13th June 2018, 06:18 PM   #45
From his use of the word "traces" I can only assume he wants me to use a flat coil configuration?
I'm not so sure I'm okay with that. I'm looking for a "0 ohm" ribbon after all.
My current source amp design has a strange phase issue I'm still working out so I wouldn't be offended by using a 4 ohm load or whatever for now but If I can sidestep turning it into a 4 ohm speaker I probably would. I can just use a resistor to buffer the load from a voltage amp for now.
Is there a particular reason why the mylar config is superior to a pure ribbon other than the ability to increase the resistance?
Old 13th June 2018, 06:31 PM   #46
WrineX's Avatar
most people have a problem reaching 4 ohm just use some kitchen foil and you got what you want. 0 ohm
Old 13th June 2018, 06:31 PM   #47
WrineX's Avatar
or maybe a half or so
Old 13th June 2018, 06:32 PM   #48
richardr is offline richardr  United States
Don't turn the ribbons sideways as the. floor and ceiling bounce will be intolerable. I have done it. It is a non-starter. Only vertical ribbons as their vertical distribution is quite poor which IMO is a good thing.
What are you going to do about bass?
Good luck.
Old 13th June 2018, 06:45 PM   #49
I was actually considering a CBT arrangement. This would require me to solve my "bezel" issue though. I would need a way to keep the distance between the ribbons in the array as small as possible which can only be done if the magnet is the baffle with an extremely thin magnet and the individually tiny ribbons created by a horizontal bezel "clamp" would, supposedly (?) solve the low frequency distortion issue as well as allow a CBT arrangement to be practical.
Unless someone has a brilliant idea how to approach the construction of such a thing I'm going to use Lowmass's idea with a cone woofer and active crossover for now. Eventually I need to get my bezel issue solved though. The more I think about the idea the more I like it.
Old 13th June 2018, 09:30 PM   #50
lowmass is offline lowmass  United States
you can use a foil only ribbon with no plastic backing if you want. You will get approx 1.5 - 2 db increase in sensativity due to lower mass.
However if you are going to corrugate the "FO" ribbon you will always have a nasty resonance somewhere. This resonance is a function of the mass and spring stiffness of the corrugations. Larger corrugations will push this resonance higher in freq. Usually with a 1 inch wide ribbon depending on corrugation size you will see a resonance somewhere between 2 and 5 khz. Lower if a 2 inch wide. This is not a good area for a Feq response glitch.
Generally any FO corrugated ribbon bigger than about 12-15mm wide will have trouble here.
The plastics with traces are much better damped and well behaved through this region and easyer to get close to good.
The "zero" ohm full range ribbonHide this!Advertise here!
Helper Woofer(s) for "punchy" FAST/WWW/SAW/etc. to go w/ Fane 12" full range drivers sbcrx007 Multi-Way 227 8th January 2018 09:56 PM
1 "Foster FE103A Family" 4" Full Range Driver, Alnico Magnet, Made In Japan ~1968 cc72 Swap Meet 0 11th September 2015 06:57 AM
SB acoustics SB12MNRX25-4 "full range" Build thread wintermute Full Range 95 4th March 2014 09:15 PM
FS: Full Range Enclosures (19"w x 10.5"h x 12"d) axissilverhand Swap Meet 0 19th December 2010 12:01 AM
Full Range drivers - do they always "rip your ears off" at high volumes? chris661 Full Range 52 16th December 2009 08:25 AM
