Planars & Exotics ESL's, planars, and alternative technologies
variable HV unit to create bias of +10.000volts
Old 23rd March 2018, 11:54 PM   #11
Geoneer is offline Geoneer
well golfnut...
Did you connect the unit in an ESL?
Old 24th March 2018, 01:04 AM   #12
golfnut is offline golfnut  New Zealand
golfnut's Avatar
Hi Geoneer
No. I'm sure it would be fine, just has a lot more grunt, both voltage and current, than necessary.
The normal Cockcroft-Walton multiplier is perfectly adequate, it will bite, but only 1 or 2 on the crocodile scale. This thing is lethal - definitely keeping one hand in a pocket.
regards
R
“Nothing is more practical than a good theory.”
– Ludwig Boltzmann
variable HV unit to create bias of +10.000voltsHide this!Advertise here!
Amplifier with variable bias that indicates whether it works in A or AB MarcelvdG Solid State 15 8th June 2017 04:43 AM
Variable cathode bias in SSE: 1k Ohm pot? Horsebox Tubelab 7 7th April 2011 10:19 PM
dayton wright st300a matching / bias trnsformer unit krmaudio Planars & Exotics 14 21st October 2010 12:05 AM
Variable bias Mikael Abdellah Tubes / Valves 2 25th February 2007 07:38 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
