Planars & Exotics ESL's, planars, and alternative technologies
How to modify SMGa to Active Crossover?
Old 18th November 2017, 05:45 PM   #1
SanJoseMichael is offline SanJoseMichael  United States
Default How to modify SMGa to Active Crossover?
I've got a set of Magnepan SMGa speakers that I'd like to biamp, but I'm pretty well clueless as to how to do it.
How to wire it for biamplificaton:
First, disconnect the existing crossover.
Then do I keep the inductor in parallel with the mid/woofer?
And keep the capacitor in parallel with the tweeter?
Then, when using an active crossover, what frequency makes sense to cross over at?
Thanks!
Old 18th November 2017, 07:00 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
With passive bi-amping you need to separate the XO into 2 discrete XOs and drive each with its own amplifier. The passive XO is a series XO so a new XO configuration would be needed
With an active XO (real bi-amping) you eliminate the XO completely. The starting poing for setting your active XO is to get as close to the passive XO as possible (passive is 1st order).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th November 2017, 10:45 PM   #3
Dave -
Yes, real bi-amping, from pre to active crossover to two power amps, one for bass/mid and one for tweeters.
So, remove the passive XO from the Magnepans completely, and redo the speaker connections to allow direct connection from the each amp to each section of the SMGa's.
You said "The starting poing for setting your active XO is to get as close to the passive XO as possible (passive is 1st order)." How do I determine that? What might a guess of a good starting point be?
Thanks.
MG
Old 18th November 2017, 10:52 PM   #4
Does this suggest 800hz?
1st Order / 6 db Butterworth Crossover Table
Old 18th November 2017, 11:10 PM   #5
adason is offline adason  United States
adason's Avatar
I would suggest minidsp. As a start. It allows you to change crossover frequency, slopes, delays, levels...on the fly, while listening. Its cheap too. Sounds ok, once you get all sorted out, you can upgrade. Plus its parametric eq, you can use it to correct room.
Just a suggestion, do what suits you.
Old 18th November 2017, 11:13 PM   #6
frugal-phile(tm)
planet10's Avatar
Originally Posted by SanJoseMichael View Post
So, remove the passive XO from the Magnepans completely, and redo the speaker connections to allow direct connection from the each amp to each section of the SMGa’s.
Yes
Manufacturer specs, reviews, email Magnepan.
dave
Old 18th November 2017, 11:16 PM   #7
frugal-phile(tm)
planet10's Avatar
You might be able to use text-book XO values as a 1st pass guess. You’d really need to have impedance plots of your speakers sans Cos to get more accurate impedance values.
dave
Old 19th November 2017, 12:48 AM   #8
You guys are clearly more advanced than I am, but I ask the Tribal Elders and Wise Ones in order to learn.
Here's a very basic question: Is it worth it? I have read many places that bi-amping is worth exploring.
I am limimted in my equipment and $$ to upgrade much at this time, so my idea was this: CD Player/Aux into NAD 3225PE, Preamp out of NAD NAD 3225PE into active crossover, highs out of active crossover back into NAD 3225PE and speakers direct to Maggie tweets, lows out of active crossver into NAD 2100PE and speakers direct to Maggie lows/mid. (Alernately, into vintage Altecs, driven by Magnavox 8802 and 175).
I now drive the Magnepan SMGa speakers this the NAD 2100 PE alone, about 75 watts into 4 ohms to drive SMGa factory passive crossover speakers
Biamping suggests more power to the speakers. Active biamp = NAD 3225PE (About 30 watts into 4 ohms) for the high range, NAD 2100 (About 75 watts into 4 ohms) for the lows. Net difference: From 75 watts to passive crossover to 105 watts active crossover.
Or should I just sell off my old NAD stuff and get a Denon, Sony, Yamaha, Oinko, Pioneer AV reciever puting out about 140 to 150 watts (8 ohms), or find some 200W beast on Craigslist for cheap?
Old 19th November 2017, 02:26 AM   #9
frugal-phile(tm)
planet10's Avatar
Using the NADs is a fine approach. We sold a lot of NAD3020 with the promise of easy bi-amping in the future.
dave
Old 19th November 2017, 03:45 AM   #10
kevinkr's Avatar
As others have alluded you need to remove all of the existing XO parts. The tweeter is somewhat fragile so the fuse should be retained.
I have include a simulation of the current XO response. Because the drivers look predominantly resistive the response is pretty close to text first order network amplitude and phase response.
First graph is just the series XO and drivers, the second is an overlay with a classic first order 2 way xo. There is no difference.
Looks like first order crossover at 800Hz would be fine.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
How to modify SMGa to Active Crossover?Hide this!Advertise here!
SMGa Crossover Schematic and Drawing Freecrowder Planars & Exotics 12 2nd May 2018 10:23 PM
Got a tda2030a 2.1 amp from ebay, want to modify the crossover rudyauction509 Chip Amps 21 29th July 2014 06:48 AM
Need your advice to modify crossover. floatingfloc Multi-Way 30 25th June 2012 02:01 PM
Modify MTX crossover ? ? poopydoopynoopy Analog Line Level 1 12th September 2010 02:32 AM
Modify crossover frequencies for 3-way design snoopy33 Multi-Way 4 22nd December 2009 01:25 AM
