Planars & Exotics ESL's, planars, and alternative technologies
ML Odyssey lower volume on 1 panel
Old 21st November 2017, 05:09 AM   #21
sumotan is offline sumotan  Indonesia
Yes one speaker is still working normally
Old 21st November 2017, 10:22 AM   #22
tyu is offline tyu  United States
I know one thing .... We here on the planars & Exotics site... would be lost with out people like Bolsers an minny others..... thanks for the years of just be here....an all your help.....
An to All.....here on this great Diyaudio site......"Happy Holidays!"
Old 21st November 2017, 11:30 AM   #23
Yes I agree & am very thankful to Bolserst & you Tyu for my ML issues & also to others guys in other side of the forum.
Thanks to all.
Old 21st November 2017, 02:44 PM   #24
Well ironically Bolserst, it only ready 41vac.
So can we confirm that the transfomer is gone ?
Thks
Old 21st November 2017, 02:47 PM   #25
bolserst is offline bolserst  United States
bolserst's Avatar
Yeah, that sounds like transformer is bad.
Just to make sure I pointed out the correct measurement locations, I'd repeat test on the good supply.
Old 21st November 2017, 02:54 PM   #26
Ok will repeat the test on the good board. I also flipped the board over & measured directly
on the trafo output. Same readings. Can this be bought from ML ?
Guess it was just waiting to go down hence the volume issue that I experienced.
Thank again Bolserst.
Old 21st November 2017, 03:38 PM   #27
bolserst's Avatar
Just to make sure, attached is pic of where you should measure the transformer on the back side of the board.
Andersonix was able to purchase a replacement transformer in the US a few years ago.
ML SL3 intermittent bias supply problem
Old 21st November 2017, 03:40 PM   #28
Ml....had the boards....was $50...but knowing them $100 to day..Not being Neg...that's like we know is life to day....
I have two bias that I can sat...3k-6k...cost less to diy...an the panels like all ESLs sound better....when bias on all the time!
But I do a lot of qiuk ck on ESLs panels...I pick up...two diy bias part setups.... less than $50-80
But if you wont
stock....ML
Right I for got about just geting the Trans....that may work...Hehe
See Bolserst ....the man come though Again....life saver...well maybe just money...
good luck
Old 21st November 2017, 03:50 PM   #29
Yes Bolserst that’s where I measured . Also if I measured resistance no readings,
dvm just fluctuates
Thanks again
Old 21st November 2017, 03:51 PM   #30
Do you have boards to sell me Tyu ?
ML Odyssey lower volume on 1 panelHide this!Advertise here!
lower enclosure volume adhith94 Multi-Way 1 16th September 2017 05:05 PM
TDA7492P 50W/50W Ebay - AUX Input Volume Lower Than Bluetooth Volume? iammrhappy123 Chip Amps 4 9th November 2015 11:40 PM
lower intercom speaker volume broman973 Everything Else 0 15th March 2014 06:08 AM
Help with FR and lower volume JLL Full Range 4 20th May 2006 03:13 PM
