Planars & Exotics ESL's, planars, and alternative technologies
ML Odyssey lower volume on 1 panel
Old 20th November 2017, 04:31 AM   #11
sumotan is offline sumotan  Indonesia
Thank you very much Bolserst,
Will verify the voltage. Yes I have
measured those strings of 10 meg resistors all reading above accept 1 which reads only 8 meg or so, wondering if it has any effect on lowering the volume.
My Odyssey is an old lady now. Since Iíve already open her up, do you have any suggestion on servicing the bias board Bolserst ? I do notice that on both boards
the side where the HV is located are all yellowed seems like it running hot.
Also the red led does not light up even when music is playing.
Many thanks again for your kind advice
Old 20th November 2017, 05:36 AM   #12
Hi Bolserst,
Dilemma time. Clean the board before re installing confirm that all connections were correct, power up only got distorted sound at high volume. Could not make any measurements at C12 cause voltage was just fluctuating all over. Would this have to do with the sensing circuit or ????
Thank again for for patients & help
Old 20th November 2017, 09:31 AM   #13
tyu is offline tyu  United States
These boards can,well go bad....I have had to replace, vary hard to work on ...but you see that...there also the chip on the board....can go bad.....I have had ML send new chip ....for free...
Never seen yellowed boards.....you may need to get two new boards.....if your sure it not the panel?...
good luck
Old 20th November 2017, 10:07 AM   #14
Thats bad news Tyu. Anyway since Im already trouble shooting, I was thinking I mignt as well prepare for resotration work on the panesl if possible.
Is it possible to remove stator without demaging the Mylar film TYU ?
Your the expert who appreciate your advice.
Thanks again
Old 20th November 2017, 05:03 PM   #15
Well now geting the side rails off can done.... But.....I don't think you well ever get them back on.....each rail is full of sticky rubber type ...you well see....as for geting the panel apart..... Ive got more of these type panels apart with out riping...than the older sl3 type... as you may know panels are only glued togather at the top an bottem.....
So you are SURE its The panel that's bad??....
Only do pull the panels... IF you have.....nothing to lose....!.....if you have new panels you well still need bias.....or thay well not work...............good luck
Old 20th November 2017, 05:50 PM   #16
No panel aren’t bad. Just asking you from your experience.
If I were to restore the Odyssey I would try to do everyhing
at one go . Panels will go bad cause it’s already that old just
don’t know when.
Many thanks again TYU
Old 20th November 2017, 08:44 PM   #17
Ok....got it..... an glad to help....
the one thing I would do is put the Ascend Xo in, an do change the setup transfourm secdairy...as well...an it should give the old panels...more better output....pull up a ML Ascend OX..have look..... same panel same stepup trans in the two speakers... just diff taps....have fun
Old 21st November 2017, 02:14 AM   #18
Yes Tyu you mentioned this to me before. I actually bought the parts to built the Ascent XO already. Lol Does changing that wire on the step up trans make alot of difference to the sound ?
Thanks again
Old 21st November 2017, 03:55 AM   #19
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by sumotan View Post
... confirm that all connections were correct, power up only got distorted sound at high volume. Could not make any measurements at C12 cause voltage was just fluctuating all over.
Hmmmm...sounds like I have missed something along the way. At the beginning of the thread you said one speaker was a little quieter than the other. Now you are getting very little output. Very little output(and distorted) sounds like you are not getting any bias voltage to the panel at all.
A few questions to help me understand:
1) Is one speaker still working OK?
2) Could you get a solid 300VDC reading from one of the speakers but not the other? or were both of them fluctuating. You will not get a solid reading if the auto-ON has not been triggered.
3) You mention that the LED on the board does not light. This LED lights when the auto-ON is triggered and the HV supply is activated. Does the LED light on one board but not the other? Had you ever seen the LED light on either board?
A preliminary step you might check is the output of the power transformer that feeds the HV multiplier. It should measure about 240-250 VAC when the power cord is plugged in. You should be able to measure this voltage at all times whether or not there is an audio signal or if the auto-ON has been triggered or not.
If you confirm you have this voltage present, I can show you how to temporarily bypass the auto-ON function to check that the rest of the HV supply is working OK.
Old 21st November 2017, 04:07 AM   #20
Yes Bolserst your reading correctly. Originally only lower in volume on 1 panel. Remove HV board from good speaker to test. Bad speaker sounded ok so confirm Hv board is problem area. Re install good HV board back onto the good speaker. Re install bad Hv board back into bad speaker just to varify again. Yep all not sound accept at almost full volume which is distorted. I understand what the music sense signal is suppose to do thats why I ask why do I get music playing even when red led is not lit. This is on the good speaker as well.
Thanks again Bolserst
ML Odyssey lower volume on 1 panelHide this!Advertise here!
lower enclosure volume adhith94 Multi-Way 1 16th September 2017 04:05 PM
TDA7492P 50W/50W Ebay - AUX Input Volume Lower Than Bluetooth Volume? iammrhappy123 Chip Amps 4 9th November 2015 10:40 PM
lower intercom speaker volume broman973 Everything Else 0 15th March 2014 05:08 AM
Help with FR and lower volume JLL Full Range 4 20th May 2006 02:13 PM
