Planars & Exotics ESL's, planars, and alternative technologies
SLAM
SLAM
Old 6th January 2018, 05:08 PM   #31
TNT is offline TNT  Sweden
Serious stuff!
Good luck!!
More distortion to the people!
Old 8th January 2018, 09:25 PM   #32
solhaga is offline solhaga  Sweden
Eight segments mounted, that is nearly a quarter of a SLAM!
Backside:
It's looks so good, so good!
Old 31st January 2018, 06:35 PM   #33
Designed the tweeter membrane:
60 mm high and 290 mm wide will with 36 pockets yield a 48x48 mm finished membrane.
The first successful cut:
6.0 Ohm, a little bit more than the calculated 4.3 Ohm. But the return feeds, the horisontal parts, were not included in that calculation.
The motors are growing centimeter by centimeter:
Weight is now a mere 12 kg, 50 cm high.
Only 30 cm to go!
The 3D printer is working 8 hours a day:
Next step is to design a folding tool in nylon.
I have tested nylon and it seems to withstand 170 degrees Celsisus, at least for 20 minutes.
Old 18th March 2018, 11:52 AM   #34
It didn't turn out well with the nylon plates:
But I found out that the kitchen oven "ovel shoot" when it comes to the temperature. It was actually over 240 degrees.
So I decided to build an oven out of two of these and some electronics:
Then I tried poly carbonate at 160 degrees, but that was to hot as well:
Another type of jigg:
and a lower temperature, 140 degrees, did the trick:
Old 18th March 2018, 12:27 PM   #35
To fold the whole membrane in the new jigg went well as did baking it.
But the printer wasn't happy about it when I tried to make prototypes of the membrane holder:
Front:
Back:
As the holder was to be made in a softer material called TPU with a shore of 95A, didn't the extrusion gear manage to feed the extruder.
So I needed to re-build the printer. Luckily, there's a forum for that as well..
Anyway, after a week or so I managed to get a suitable membrane holder:
Front:
Back:
So in with the membrane and prepare for gluing:
Old 18th March 2018, 12:30 PM   #36
Need to rethink your pic posting strategies...?
Old 18th March 2018, 12:59 PM   #37
Everything (certificate, server, firewall) seems fine at my end.
Trouble shooting is ongoing...
Old 18th March 2018, 03:53 PM   #38
Seems to work now? I can now see the pictures on my phone.
Anyway. One tweeter mounted in SLAM!
Back:
Front:
Time to make some measurements...
Old 18th March 2018, 05:40 PM   #39
With one watt in and a sweep from 1000 Hz to 20 kHz I got:
At 25 cm:
At 50 cm:
At 100 cm (room starts to influence):
All three:
I think it looks good.
Nothing that points to a reconstruction of the membrane.
Next step is to make the terminals better
Old 18th March 2018, 10:37 PM   #40
WrineX is offline WrineX  Netherlands
WrineX's Avatar
HEej Solhaga you still use the 3m material ? or what did you use as membrane?
SLAMHide this!Advertise here!
Crown macro and studio reference amps: what's the secret of their slam ? elac310 The Lounge 247 11th October 2014 08:56 PM
Best slam and punch in the bass for hifi (not PA): TH with 15 OR 2x15 BR OR 1x18 BR? pk Subwoofers 29 8th July 2013 08:51 PM
SDX10 tips for slam? caper26 Subwoofers 8 14th June 2012 11:51 PM
Email Slam. jleaman Everything Else 5 18th December 2003 12:49 AM
Wilson Audio Grand Slam X1 - Clones Percy Erasmus Multi-Way 13 30th April 2002 01:50 AM
