Planars & Exotics ESL's, planars, and alternative technologies
SLAM
SLAM
Old 25th September 2017, 06:05 PM   #11
solhaga is offline solhaga  Sweden
I've decided to make the plastic parts myself.
So I've ordered the new Prusa i3 Mk3 3D printer.
Unfortunately it is not due until November...
Old 25th September 2017, 08:37 PM   #12
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Originally Posted by solhaga View Post
Thank you, Wrinex.
Did you by the way visit any of the Piet Mondriaan exhibitions this summer?
not that I know of although I live in the Hague
Old 1st October 2017, 08:42 AM   #13
Default SLAM!
Got some prototypes made of the pole piece holders:
Some minor errors: fillet where the vertical part ends in the horisontal part should have had a larger radius and there should be no fillet on the bottom plate.
First try of the mounting:
The holders should have the same contour as the pole piece at membrane.
The backside, where the magnets will be mounted:
It could of course be good to cover the nuts with some snap-in so it'll be the same contour towards the membrane/gap all the way.
Test mount in the frame:
Old 14th October 2017, 07:31 PM   #14
Default SLAM prototype v2
I'll replace the small aluminium parts with 3D printed:
I can then premount a complete two pole piece section (you'll have to ignore the aluminium part here):
Another angle:
I'll force the sections down the aluminium frame "rail":
When in place I'll secure the section at the aluminium frame with a screw though the section and frame.
Hopefully will this be a lot faster and much more secure.
Old 24th October 2017, 05:53 AM   #15
While waiting for the printer, I'll need some advice from the forum expertise.
The ideal motor looks like this:
Simulated flux density:
Horisontal plot:
Linear and even through the gap.
But the reflexion of the back wave produces all sorts of distortion both in time and frequency when it is mixed with the front wave.
So after a couple of measurements with different back pole pieces, I decided to skip the back pole pieces all together.
The flux density is now un-linear and varies a lot over the gap.
Now I'm wondering if there a way to disperse the reflexion.
Considerably better linearity over the gap.
But is the back pole piece curved the right way to make the desired dispersian?
Shall it have a larger radius? (Larger radius means greater variation.)
Other thoughts?
Old 24th October 2017, 07:55 AM   #16
The back pole piece can be straight across the gap to get a linear flux density.
Convex or concave curvatures towards the membrane are easily made from printed plastic details that are glued to the pole piece.
Old 24th October 2017, 05:27 PM   #17
båndsei is offline båndsei  Denmark
Hi Solhaga
I don´t use back pole for my AMT´s.
Using back pole increases sensivity and give a much more linear magnetic field.
My idea is to use round bars to omit reflexions .
Use a angle grinder to cut the ends like this:Udklip.PNG
Bernt
Old 24th October 2017, 06:07 PM   #18
Originally Posted by båndsei View Post
Hi Solhaga
Use a angle grinder to cut the ends like this:Attachment 641975
Bernt
Yeah, that's a great idea.
Instead of using a grinder, a 5x5 mm square rod can be used that can have your suggestion glued to it or a concave or a convex or a ...
Old 29th October 2017, 04:14 PM   #19
As the configuration is MMTMM, the section where the four mid membranes are can have back pole pieces.
This as the reflections have little impact for that frequency interval.
I'm also considering to make the mid membranes to go lower, let's see what properties that will have to change - pleat depth, pleat width and/or foil thickness/width.
Then I will see if the small tweeter membrane in the middle can cope with back pole pieces.
That membrane's properties will of course be changed as well, apart from being shorter of course.
Back pole piece:
I will test this in my current motor.
Simulations looks good!
SLAM! two pole piece complete assembly:
Old 4th November 2017, 04:29 PM   #20
Hi Solhaga
I have tried to become member at faktisk.se to make a comment to your SLAM project.
At the registration site you are given a security question to prevent spambots
In SWEEDISH.
A comment to the other site. You can increase the field strength in the tweeter gap using this bar:solhaga bar tweeter.PNG
Are the iron bars saturated ?
Bernt
SLAMHide this!Advertise here!
Crown macro and studio reference amps: what's the secret of their slam ? elac310 The Lounge 247 11th October 2014 08:56 PM
Best slam and punch in the bass for hifi (not PA): TH with 15 OR 2x15 BR OR 1x18 BR? pk Subwoofers 29 8th July 2013 08:51 PM
SDX10 tips for slam? caper26 Subwoofers 8 14th June 2012 11:51 PM
Email Slam. jleaman Everything Else 5 18th December 2003 12:49 AM
Wilson Audio Grand Slam X1 - Clones Percy Erasmus Multi-Way 13 30th April 2002 01:50 AM
