Planars & Exotics ESL's, planars, and alternative technologies
BG NEO 3 FR optimization
Old 2nd January 2018, 10:30 PM   #31
dheming is offline dheming  United States
dheming's Avatar
Originally Posted by Fjendbo View Post
Would you mind sharing your 3D model in a format Cura 3D can handle? I have a Neo3 project on the way and would love to try it out!
Looks like Cura 3D supports STL, 3MF and OBJ file formats, which will be no problem for me to export from Rhino.
However, my current model is not accurate enough to 3D print since I merely worked on top of a picture I found:
BG NEO 3 FR optimization-catenary_waveguide_02-jpg
I can pretty much guarantee that it won't line up with a real Neo3. So I'm going to head over to storage today and look for my tweeters. Then I can measure them properly with calipers and make a new model. When it's done I'll post it on my GrabCAD profile so that anyone can download it.
Old 3rd January 2018, 07:10 AM   #32
Fjendbo is offline Fjendbo  Denmark
Sounds absolutely terrific! Thank you
Old 3rd January 2018, 11:31 AM   #33
Tazzz is offline Tazzz
How much effort is needed for the cad drawings?
Would you consider making a model fitting the neo8 aswell? If provided the measurements?
Old 5th January 2018, 04:56 AM   #34
dheming's Avatar
Doing the actual modeling ain't too bad at all. It's the taking careful measurements of every single detail that takes time. So yeah, if you provided measurements for the Neo8 I could make a model for it as well pretty quickly.
Speaking of which I finally got my Neo3 tweeters and calipers from storage today. Had to deal with automotive trouble the past few days. :/
Old 5th January 2018, 07:54 AM   #35
Actually, I would be interested in a model for the Neo8 as well
Old 5th January 2018, 11:28 AM   #36
RogerGustavsson is offline RogerGustavsson  Sweden
The Neo 8 have a problem with the internal resonance, some kind of standing wave between the front and rear plates. Removing one of the removes the problem but you also reduce the output level and so´me changes at the lowest frequences.
Old 5th January 2018, 11:16 PM   #37
dheming's Avatar
So I just finished taking detailed measurements of one of my Neo3 tweeters. The numbers show that each window is a different size:
BG NEO 3 FR optimization-neo3_print_01-png
Old 5th January 2018, 11:25 PM   #38
dheming's Avatar
Worse yet, the windows are not in a neat grid either. They deviate substantially from where they should be centered, which is a much bigger issue. So the perfectly spaced waveguide model will never match up with the real world tweeters due to the terrible punching tolerances.
Further, when I scaled the image from Parts Express to the measured width of my tweeter I get this:
BG NEO 3 FR optimization-neo3_print_02-jpg
So I'm not sure if the newer tweeters have the same height for the windows? I ordered my Neo3 pair back in 2004.
Old 5th January 2018, 11:31 PM   #39
dheming's Avatar
When I get back home I will post two versions of the 3D model for the waveguides:
1. Version made by tracing the Parts Express image.
2. Version made using measurements of my tweeter.
Old 6th January 2018, 12:49 AM   #40
dheming's Avatar
Link for the Parts Express traced version: GrabCAD - CAD library
BG NEO 3 FR optimizationHide this!Advertise here!
Bg Neo 10 and Neo 8 InclinedPlane Planars & Exotics 253 27th June 2018 06:59 AM
BG Neo + RD are no more to DIY ezrider4040 Planars & Exotics 9 24th April 2016 06:03 PM
WTB: NOS BG NEO 10 & NEO 3 Drivers DQ828 Swap Meet 13 18th September 2015 08:26 AM
Ideas for BG Neo 8 Jvsantosmd Planars & Exotics 5 26th January 2014 03:39 PM
BG Neo 10 whoever Swap Meet 0 7th November 2012 01:56 AM
