Planars & Exotics ESL's, planars, and alternative technologies
Monsoon - Surprisingly Good!
Old 26th July 2017, 11:45 PM   #41
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by Atom666 View Post
I bought a lot of them years ago when Monsoon went out of business and the remaining stock started turning up at surplus dealers…When you measured the MM700 was the driver out of the Plastic grill/stand? Also was the felt damping on the back of the driver in place?
Nice acquisition!
Measurements were made with the “naked” driver mounted to a slender stick.
I did this for my own selfish reasons to make comparison with BTM diffraction theory easier.
The only felt damping I noticed was a thin layer mounted to the rear magnets. Is that what you were talking about?
Or, do some versions have some additional felt between the driver and the rear grill.
The thin felt made surprisingly little difference to the HF response as the front .vs. rear response comparison plot shows.
I also attached a near field measurement showing two diaphragm resonance modes that I thought you might find interesting.
Old 28th July 2017, 08:29 PM   #42
Atom666 is offline Atom666  Canada
Atom666's Avatar
Thanks for that! I just not sure how to correct the problem.
Old 7th August 2017, 07:44 PM   #43
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Just so everyone knows there a three different types of Monsoon driver in this general configuration. The first generation is in the MM-1000 , the second in the MM-700 ( straight sides) and the third in the MM-702 (wavy sides) this is the version that VMPS used in their speakers.
Andrew
Add the MH-502 and the PM-9, and that makes 5 versions.
I think both of these use non-plated magnets, so should not have a problem with corrosion of plating leading to buzzing. PM-9 is also held together with screws for simple disassembly if needed.
I have recently acquired a pair of PM-9 and looking at redesigning the accompanying bass section for them.
Thanks Bolserst for the curves!
Old 7th August 2017, 09:04 PM   #44
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The pd ribbob in the MH-502 is much smaller and used as a tweeter with a 2.5” midrange. Woofer is a 4” (meaures across 10+ units show a high level of variability.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th August 2017, 06:34 PM   #45
audiomagnate is offline audiomagnate  United States
Originally Posted by bentoronto View Post
I am not surprised that your manners are as poor as your knowledge of hearing. You mistake average hearing for individual hearing under your urge to be disparaging.
And you don't seem to know anything about the frequency range of musical instruments.
B.
I worked at the bioacoustics lab at the University of Pittsburgh for several years, researching, among other things, presbycusis (age related hearing loss). Typical loss at 6,000 Hz in an 80 year old is around 40 dB, higher if you've worked in a noisy environment. I assumed you were in this age range from a signature, "HiFi aspirations since 1957."
As to the frequency range of instruments, it is common knowlege in the recording industry, (where I've also worked) than many instruments extend well past 20K, let alone 6K. Muted trumpets put out strong energy out to 80K, as anyone who has mastered a record knows. Lowmass, here's an informative article on the range of musical instruments: There's life above 20 kilohertz! A survey of musical instrument spectra to 102.4 kHz
As you can see, there's a lot up there!
Old 15th August 2017, 04:14 PM   #46
Greebster is offline Greebster  United States
Greebster's Avatar
The PM9's have unplated ferritesque magnets in them.
Old 15th August 2017, 11:05 PM   #47
frugal-phile(tm)
planet10's Avatar
All of the Monsoon ribbons from 1st gen to 3rd gen have unplated ferrite magnets — i have disassembled them all.
dave
Old 16th August 2017, 12:30 AM   #48
dave
But that's not a problem AFAIK. Unplated ferite doesn't crumble into dust over time like the samarium cobalt magnets in my old Infinity 2.5s did after the plating failed.
Old 16th August 2017, 12:49 AM   #49
frugal-phile(tm)
planet10's Avatar
True, it only breaks & chips.
dave
Old 16th August 2017, 04:57 AM   #50
Andersonix's Avatar
dave
Maybe you mean 2nd gen? Because the MM-1000 f.ex. had nickel plated magnets and could turn to dust.
Monsoon - Surprisingly Good!Hide this!Advertise here!
Monsoon Dreams Bose(o) Planars & Exotics 8 15th July 2015 09:25 PM
monsoon planar ibanez59er Planars & Exotics 1 10th February 2012 08:02 PM
Old and surprisingly good amp hahfran Solid State 20 26th March 2011 01:30 PM
Surprisingly good "amplifier" for Betsy K roger_lew Wild Burro Audio 6 11th July 2010 10:48 PM
