Planars & Exotics ESL's, planars, and alternative technologies
I cant reach above 15Khz on my planars
Old 7th May 2017, 07:35 PM   #41
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Here bolserst
my cal file of the new mic
File Type: txt EMX-7150-1041666-250116-freefield.txt (842 Bytes, 21 views)
Old 8th May 2017, 12:10 PM   #42
RogerGustavsson is offline RogerGustavsson  Sweden
Originally Posted by bolserst View Post
Thanks for sharing your experience. I've often wondered about this aspect of planar magentics where there is often a significant portion of undriven diaphragm area that is just "along for the ride".
For lower frequences, there is a elasticity needed to allow for larger deflections. If the plastic film is largely overed with aluminum foil, it will reduce the ability to excursion for a non-pleated diaphragm.
Old 8th May 2017, 06:05 PM   #43
lowmass is offline lowmass  United States
Good point. In general though a panel doing lower freqs will be quite large so this potential problem doesnt seem to be an issue.
I have built a number of basic panels with the foil traces running BOTH ways. The results were the same.
Another case in point, the Apogee base panel has its foil traces running horizontally AND they are under tension in that direction. Meaning across its width there really is no breaks in the foil. Similar to no traces at all, yet it works.
Old 8th May 2017, 07:05 PM   #44
WrineX's Avatar
Also a magnepan foil is tensioned REALLY really hard. to the brink of destruction. if not tensioned you get the comb filter i showed. so as much tension is needed as possible , enlarge the panel to get lower res.
Old 15th May 2017, 03:01 AM   #45
bolserst is offline bolserst  United States
bolserst's Avatar
Thanks!
Wow, that is impressively flat.
Almost don't need to use the Cal file at all.
Old 15th May 2017, 06:06 AM   #46
WrineX's Avatar
Thanks!
Indeed just max 1 dB or so from 20-20khz nothing much happening there
I cant reach above 15Khz on my planarsHide this!Advertise here!
loudest 3 inch which reaches to 15KHz for Karlson tweeter? freddi Full Range 36 22nd May 2018 08:25 PM
NOS dac, 15KHz wave test Strange results erez1012 Digital Line Level 11 29th September 2016 04:25 PM
oh my gosh, I can't hear 15kHz :-( Bigun Full Range 95 29th April 2012 09:27 PM
My ears max out at 15kHz and I'm only 31...how depressing. GregH2 The Lounge 12 28th March 2011 09:40 PM
3Khz/3.15Khz Test LP WANTED GUILHERME Swap Meet 6 19th May 2004 10:05 AM
