DIY planar magnetic + open baffle woofer array
I'm afraid not. I designed them (I assume you mean the planar magnetic panels...) for dipole use so I didn't really have a reason to measure Vas. Because of the stretch-wrap "surround" around the kapton tape diaphragms, the tension is likely lower than if I had directly clamped the kapton to the edges of the frames. I don't have numerical value to quantify things, though.
Few
