Thanks and I admit the obvious, total ignorance. But I was under the impression that the impedance curve on esl transducers is backwards. If the impedance rises to 15 ohms, then the 30.5 puts out much less than 30w,whereas the output doubles at low impedance. Is this not correct?
Sent from my Nexus 6 using Tapatalk
i think overal it is just to low on power. altrough my class D 50 watts can drive my esl63, not saying it sounds the best but i must admit i did not hear much difference between the class D and my 2x100watt 8 ohm amp witch can handle down to 2ohms. noise floor is higher that was easy to spot
