Planars & Exotics ESL's, planars, and alternative technologies
Any Direct Drive ESL Amp projects someone could share?
Old 22nd November 2017, 02:37 AM   #81
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
Originally Posted by esl 63 View Post
Why solid state? Tubes and direct drive ESL is a perfect match.
My Beveridge is playing just awsome and you can see the schematics above nr:73
The tubes are dirt cheep and there is a lot of them... so what are you waiting for guys and girls?
The schematics shown at post #73 contains some erratics :
Both bases of differential amp Q6 and Q7 are tied together, in this way they will output nothing.
Q4 and Q5 are fully shorted at all pins.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 22nd November 2017, 06:34 AM   #82
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
There's also the large capacitance across the 'transducer'. That can't be right.
It seems this is a schematic derived from a board, and it's very hard to do that right.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 22nd November 2017, 04:09 PM   #83
bolserst is offline bolserst  United States
bolserst's Avatar
It does look odd , but actually is correct.
The transformer and direct-drive version of the Beveridge circuit topology are shown in attached pic.
This drive method enables you to get twice the voltage differential between the diaphragm and stators for a given amplifier output capability, so 2x the SPL. Essentially this is a form of amplifier bridging for ESLs. The downside is that it only works with highly conductive diaphragms.
It is very similar in concept to the Final “inverted” circuit arrangement.
More details and comparisons between the two methods posted here:
Beveridge vs Final ESL Configuration
Old 20th July 2018, 07:31 AM   #84
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
You do not need a lot of power to drive an ESL. The output impedance should be reasonable low because of the capacitive nature of the panels.
I have build many DD amps for more then 10 years now and all work stable. No tube failures so far and enough power to drive 8 Acoustat panels.
I suggest you start with the Beveridge amp as these tubes are very good and can be replaced by the PL509/519.
I do not like any solid state component therefor i replaced all transistors by tubes and omitted the filtering during prototyping.
Once you have a working amp you can add all the filtering you like.
To get a low output impedance you will have to add some (DC) feedback as this also stabilizes the DC bias on the output tubes and prevents runaway of the tubes.
Old 6th August 2018, 11:00 AM   #85
Lampie519's Avatar
I just started recycling my old Acoustat amps:
Any Direct Drive ESL Amp projects someone could share?Hide this!Advertise here!
ESL Headphone direct drive Bazukaz Planars & Exotics 22 28th April 2012 10:07 PM
ESL Direct Drive Atom666 Planars & Exotics 6 5th October 2008 08:09 AM
ESL Direct Drive SS amp jgwinner Solid State 34 30th August 2004 06:42 PM
Portable direct drive amplifier for ESL headphones shyfx Solid State 6 11th May 2004 10:54 PM
All triode no feedback direct drive for ESL Liudas Tubes / Valves 0 28th April 2002 07:31 PM
