Planars & Exotics ESL's, planars, and alternative technologies
Any Direct Drive ESL Amp projects someone could share?
Old 27th March 2016, 01:36 PM   #21
Penguin87 is offline Penguin87  United States
Anyone seen this class-D for ESL design?
High-voltage class-D direct-drive audio amplifier for electrostatic loudspeakers
I can't get into the paper itself, but this might be helpful in ironing out some of the issues.
Old 27th March 2016, 02:37 PM   #22
alexberg is offline alexberg
alexberg's Avatar
DIRECT-DRIVE DIGITAL AUDIO AMPLIFIER FOR ELECTROSTATIC LOUDSPEAKERS
https://www.linkedin.com/in/john-kota-07156619
quote
Electrostatic loudspeakers (ESLs) are capable of low distortion and have desirably flat frequency response within the audio frequency range. In this paper, a novel approach is proposed for audio amplification using a high-voltage direct-digital solid-state class-D amplifier as a method that replaces impedance matching ESL audio transformers. Optical coupling is used to achieve isolation from the high-voltage side. The proposed stacked MOSFET output stage provides a solution to the voltage swing limitations of the available switching power MOSFETs. An example digital amplifier having 14-bit ADC precision PWM with fc = 50 kHz was implemented at 375 V delivering 7W into Ra =20kΩ. The digital modulator was realized on a Xilinx Virtex4 Sx35-10ff668 at Fs = 100 MHz clock.
end quote
https://www.apexanalog.com/resources/products/pa99u.pdf
Old 27th March 2016, 03:29 PM   #23
alexberg's Avatar
What would you expect from student project anyway, no pun intended.
Amp uses four FETs with rather awkward driver topology which includes fiber optics for isolation with small signal BJTs as boosters. No Bandwidth or other audio charts are given. Membrane looks graphite coated: very dark - could be publishing artifacts.
Cheers
Old 27th March 2016, 05:32 PM   #24
bentoronto is offline bentoronto  Canada
Is there a switching frequency for Class D that "computes" for ESLs acting as the clean-up capacitor?
B.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 27th March 2016, 06:06 PM   #25
geraldfryjr is offline geraldfryjr  United States
I have thought about a HV Class D system every once in a while.
But, Being an analog purist I am not ready to go down that road yet.
Besides such a system gets way more complicated than a simple Class A P-P setup would be and for mediocre performance just doesn't weigh in very well compared to an analog setup.
jer
Old 28th March 2016, 03:35 AM   #26
alexberg's Avatar
B.
As said before: there is nothing particular in the amp per se. Q=C*U => 1500*1e-9=1.5 uC => 50k*1.5e-6=75 mA. 75mA*1500V=112.5W of idle dissipation making D-class action rather questionable.
Transition time is around 4 us at +/- 750 V.
Old 2nd April 2016, 08:18 PM   #27
maudio is offline maudio  Netherlands
old thread but the contents are still very valid
http://www.diyaudio.com/forums/plana...ve-thread.html
Old 7th April 2016, 12:48 PM   #28
invisible force is offline invisible force  Germany
Hello Maudio,
any new insights regarding the transformer working in a nested feedback loop with serial R/L combination inside the outer loop ?
Old 15th April 2016, 10:28 PM   #29
I got an email today about some new SIC FET's at Digikey and I really like there specs!!
They have a very low Coss (output capacitnace) in the range of 15pf-30pf !!
These may work very nice for my Desktop models and slightly large Bookshelf type of ESL's.
1200V, 85watt,
http://rohmfs.rohm.com/en/products/d...ct2450ke-e.pdf
SCT2450KEC Rohm Semiconductor | Discrete Semiconductor Products | DigiKey
1700V, 69watt,
http://www.wolfspeed.com/media/downl...2M1000170D.pdf
C2M1000170D Cree Inc. | Discrete Semiconductor Products | DigiKey
1700v, 35watt,
http://rohmfs.rohm.com/en/products/d.../sct2h12nz.pdf
SCT2H12NZGC11 Rohm Semiconductor | Discrete Semiconductor Products | DigiKey
1200v, 108watt,
http://rohmfs.rohm.com/en/products/d...ct2280ke-e.pdf
http://www.digikey.com/product-detai...KEC-ND/4171677
These are about $5 or $6 or so, and are just a few of what is available.
I haven't gone through everything they have yet.
Others are in the $20 to $40 each, but must of those also have a higher Vdds and power dissipation as well.
jer
Old 16th April 2016, 03:13 AM   #30
DUG is offline DUG  Canada
Crss might be more of an issue.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Any Direct Drive ESL Amp projects someone could share?Hide this!Advertise here!
ESL Headphone direct drive Bazukaz Planars & Exotics 22 28th April 2012 10:07 PM
ESL Direct Drive Atom666 Planars & Exotics 6 5th October 2008 08:09 AM
ESL Direct Drive SS amp jgwinner Solid State 34 30th August 2004 06:42 PM
Portable direct drive amplifier for ESL headphones shyfx Solid State 6 11th May 2004 10:54 PM
All triode no feedback direct drive for ESL Liudas Tubes / Valves 0 28th April 2002 07:31 PM
