Planars & Exotics ESL's, planars, and alternative technologies
DIY ribbon dipole tweeter, reductio ad minimum
Old 30th May 2017, 05:22 PM   #371
glowing vinyl is offline glowing vinyl  United Kingdom
Default Greetings all
Hello Gerrit and others
Recently read the whole thread. Gerrit, I was very impressed with the symmetry and the waterfall of your creation. Good work. The thread has been quiet for a long time are there any developments ?
I was thinking of possibly using two tweeters one above the other arranged at 90 degrees to each other in a 'T' shape to possible improve the Dipole Dispersion. What do people think ?
James
Old 31st May 2017, 07:35 AM   #372
Gerrit Boers is offline Gerrit Boers  Netherlands
James
Thank you
The ribbons are still in use and work like a charm so I didn't feel the need to change anything. I've been thinking about the alternatives for the way the ribbon is mounted but haven't come up with an idea worth testing.
As for your suggestion to use two ribbons, I'm afraid you'd end up combining the worst aspects of the directivity in stead of the best and there's the issue of the interference of the two drivers at the lower end. Alas, a ribbon like this will never be a point source otherwise it would be a near perfect HF driver. One could create a line array to 'solve' the vertical directivity but array's have their own problems.
Gerrit
Old 5th June 2017, 09:33 AM   #373
carolus is offline carolus  Belgium
Originally Posted by Gerrit Boers View Post
.....The ribbons are still in use and work like a charm so I didn't feel the need to change anything .....
Hi Gerrit ....
Thank's for sharing your knowledge & craftsmanship .... & disclose your tech/music art.
I listened (yesterday) to your (actif) set up ... breathless.
Congrats ..... chapeau bas ... hoedje af ..... it's very fine music.
(& amazing tech stuff/concept/cabling)
Regards .... Allez, salukes.
Karel
Old 28th October 2017, 12:01 PM   #374
Edmund is offline Edmund  Netherlands
@Gerrit Boers
Absolutely brilliant job with a great result.
Respect.
Old 28th October 2017, 04:58 PM   #375
Originally Posted by Edmund View Post
@Gerrit Boers
Respect.
Thank you
I still enjoy them very much. You're welcome to visit and have a listen if you'd like.
regards,
Gerrit
Old 29th October 2017, 04:26 PM   #376
Thank you
regards,
Gerrit
Thank you I love to come and listen.
Old 13th November 2017, 12:44 PM   #377
lowmass is offline lowmass  United States
Originally Posted by bolserst View Post
I know part of your strategy to address the challenge has been to create magnet configurations that improve the uniformity of the field strength across the gap. I have been meaning to ask, how did you decide on 20mm for the width of your ribbon? When I built my test ribbon from Neo8 magnets I used 3/4"(19mm) gap just because I had some leftover spacers of that dimension already cut out from some ESL experiments.
The reason I ask about your chosen gap width is that the JonasKarud ribbon calculator makes it really easy to see that reducing gap width below 20mm can dramatically improve field uniformity. Not having experimented much with ribbons, my original thought was that there would probably be some optimum gap width for best efficiency since increasing gap width reduced field strength but increased radiating area.
However, this may not be the case. According to the ribbon SPL equations, the far-field SPL is proportional to average field strength and Length, but is not a function of width. So if two ribbons have the same length, but one has half the width of the other what would happen? (Assume for a moment that average field strength was the same.) If driven by the same current, the total force on the ribbon is the same, and the far-field SPL would be the same. This would also mean that the half width ribbon would be moving twice as far as the full width ribbon. Now we know that the field strength will be greater for the half width ribbon so it should be louder than the full width ribbon for the same current…likely by 2dB – 3dB.
So, more uniform magnetic field and no loss in sensitivity? What is not to like? Why not keep reducing the gap width and keep gaining improvements? Well, there is the matter of the doubling of ribbon motion for each halving of ribbon width. Also, there will be doubling of heat dissipated in the ribbon for each halving of width. I’m not sure which is would be the more limiting factor…the heat or the increased ribbon motion.
Ok…that was me just thinking while I was typing.
Has anybody tested ribbon of different width but same length driven with the same current?
If not, I may just have to give it a try to compare SPL and distortion for the same drive current.
Ha I know this is a little late coming but...
I have done this experiment a number of years ago. Basically made a magnet assembly with adjustable gap. It was 100mm long and used neo magnets 12mm deep. Built a number of ribbons from 8mm wide to 20 mm wide. Magnet assembly was set to give 1/2 mm space between ribbon and magnets each time. BTW it is extremely important to get exactly the same space between ribbon and magnets in each test or your data is worthless.
To get same power through each ribbon a 10 ohm resistor was in series with each. No transformer.
In the end you get the same sensitivity from all of them, BUT lower distortion from the larger surface area units. This was done with 4 foils. 4 micron, 9 micron, 12 micron, 18 micron. Also a number of ribbon configurations..flat,corrugated, embossed, pure foil, foil/film laminates etc etc etc
Old 13th November 2017, 02:13 PM   #378
BTW more on above...
I do not see a dropoff in HF response to be related to ribbon width as some have mentioned. This drop off was strongly dependent on ribbon mass.
Also its interesting to me that we all seem to believe that distortion should be more of an issue as the magnets are spaced farther apart as in a wider ribbon. The assumption is that the field is less uniform so distortion should increase. However I have not seen this to be so in practice. Perhaps distortion does increase a bit?? BUT maybe is offset by the lower ribbon movements?? I consistently get lower distortion with wider ribbons reguarless of magnet geometry's. Within reason of course.
Old 14th November 2017, 04:18 AM   #379
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by lowmass View Post
…I have done this experiment a number of years ago…To get same power through each ribbon a 10 ohm resistor was in series with each…it is extremely important to get exactly the same space between ribbon and magnets
Thanks for sharing your experience.
Based on your website and patent, would it be a good assumption that your experiments were for a closed back ribbon not a dipole? If so, I need to dig up formulas for SPL of closed back ribbons.
Were you really measuring at same power? Or did you mean same current thru the ribbon.
Yes, the gaps between ribbon and magnet can have a pronounced effect on SPL . Did you consider comparing output for gaps that were sized proportional to the ribbon width so the gap effect would be similar for each ribbon? A 0.5mm gap has more effect on the SPL of an 8mm width ribbon that a 20mm.
Agreed. For ribbon microphones width affects HF response, but not for ribbon loudspeakers.
It is the mass of the ribbon relative to the airload resistance that causes the HF roll-off.
This makes reasonable sense…minimizing motion being more important than field linearity in a transducer that doesn’t really have much displacement. Your mention of the importance of gap sizes reminded me I had read in some ribbon patents that gap size affected 3rd harmonic distortion as well. Most likely that has to do with differing airload and resulting motion on the edges of the ribbon vs the middle of the ribbon. Is this something you have experimented with? The patent verbage implied there was an optimum gap size.
Old 14th November 2017, 12:46 PM   #380
Good question. Actually those measurement were dipole. I did do some quick and dirty measurements closed box, however I cannot be sure of these as they were on the fly and were not set up with care
Were you really measuring at same power? Or did you mean same current thru the ribbon.Yes, the gaps between ribbon and magnet can have a pronounced effect on SPL . Did you consider comparing output for gaps that were sized proportional to the ribbon width so the gap effect would be similar for each ribbon? A 0.5mm gap has more effect on the SPL of an 8mm width ribbon that a 20mm.
[B]My intention was to have same power and current. Input same voltage into same resistance. While there are variations in ribbon resistance I assume this was swamped out by the rather large in comparison 10 ohm series resistor.The proportional gap thing is a good question. I did not do a careful examination of this but was wondering the same thing.
Yes. BTW what do you think of the effect of the magnet slot depth on that airload and HF response?
Yes 3rd harmonic is the one effected by gap. This one is presently keeping me up at night as I am now developing a smaller ribbon capable of use down to 1 Khz. I loose sleep over it because at the moment I have two versions of the same ribbon. One with 90db sens BUT that damn 3rd starts to rise below 3khz. The other is 86 db sens but keeps 2nd - 5th below .5% across the window. I suppose 86 is still quite useful in many systems but would rather go to market with 90.
I have experimented a bit with this but theres much to learn and it looks complex. At first I suspected the distortion was more to do with the sharply rising magnet field strength as the ribbon edge was taken closer to magnet face. I assumed the sharp rise in field strength there was causing the ribbon to flex hard at the edge. Again the assumption that less than uniform field was to blame. However I made a version where the exact same ribbon was installed in a magnet assembly with the exact same geometry BUT there were plastic spacers between the magnets and the ribbon 1/4 inch thick. Now we have a much more uniform field across the ribbon and the same exact gap between the ribbon edge and the plastic placer face as we had before between ribbon and magnet face. The results were the same as with no spacers. Big gap between ribbon and surrounding structure gave low distortion. Small gap showed rise in 3rd harmonic.
If there is an "optimum" gap I am not sure. In my experiments so far it boils down to a decision between lower distortion/lower sensitivity, and higher distortion/ higher sensitivity.
Now heres what Im loosing sleep over. Neather I nor anyone else I have used in listening tests can hear the difference between the low distortion version and the "higher" distortion version. Im almost embarrassed to admit it. We all can easily hear the differences when changing to different diaphragm designs, for example the difference between a foil only design and a laminated foil/ film design and some others, BUT we cannot hear a difference between the low and "high" distortion versions within each diaphragm design. The coloration of each type is easily heard, BUT we cannot hear a difference between the low and higher distortion versions within each type.
There seems to be more to the distortion argument. Perhaps its the specific distortion profile that is responsible ? 2nd 4th and 5th are very low and 3rd is not a sharp bump but rather a smooth steady rise starting at about 3khz.
DIY ribbon dipole tweeter, reductio ad minimumHide this!Advertise here!
DIY 4 Inch Ribbon Tweeter fooeywuffle Planars & Exotics 22 11th April 2016 05:51 PM
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 8 29th March 2015 08:45 AM
Diy speaker with ribbon tweeter hugligan Multi-Way 38 7th November 2013 05:08 PM
DIY: Dipole 8" array with Neo 130cm Ribbon Bent Planars & Exotics 28 6th October 2009 07:44 PM
diy ribbon tweeter project paulfk Full Range 1 24th October 2008 02:51 PM
